RV.Net Open Roads Forum: Class A Motorhomes: Hydronic Zone Heating
 > Hydronic Zone Heating
Mountain Aire34
Greenlawn, NY 11740
Posted: 01/31/08 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
Are Hydronic Zone Heating systems prone to leaks? Do they
require a special fluid? Does that fluid have a life and require
changing over a specific time period?
Lug_Nut
Newmarket , Ontario, Canada
Posted: 02/01/08 03:52am Link  |  Quote  |  Print  |  Notify Moderator
No they are not prone to leaking. Some people have experienced a leak, generally the cause was not that of the Hydro Hot, but the plumbing within the coach. Most have no issues.
They require PG boiler type glycol which is expensive, say $30 a gallon or so.
I do not know if boiler glycol has a life span or what it may be.
'07 Newmar Essex 45' ISM 500 4 slides
cRackedHead
San Antonio,tx
Posted: 02/01/08 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Vehicle Systems(Aqua Hot) requires Camco boiler ant-freeze, which you can find for 12-15 dollars a gallon.
BigRigRVing
formerly CA
Posted: 02/01/08 05:51am Link  |  Quote  |  Print  |  Notify Moderator
Ditto, we love ours and will never own another coach without one. We had our serviced and new electric element put in it yesterday, and I ask the question about fluid change/life span, I got a blank stare and uh!
Gary & Cheryl and our chocolate lab named Caddy
2005 Newmar Mountain Aire 4304 w/ Blue-Ox Sports Lift
2006 Jeep Rubicon
HD 2006 Softtail Deluxe
www.BigRigRVing.com
RTJ49
Beltsville, MD 20705
Posted: 02/01/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Hi Mountain Aire34,
We have never had a leak. Previous owner had none. This Aqua-Hot is going on eleven years. We have had it the last five years. They require a once yearly fuel nozzle, filter replacement, and check-up. We love the Aqua-Hot. Will always have this type system.
RTJ49
1997 U320 Foretravel 450 Cummins
1998 Ford Explorer
Our Foretravel
Jack&Debra
Dumas, TX
Posted: 02/01/08 08:11am Link  |  Quote  |  Print  |  Notify Moderator
We are currently dry docking in Denver. Two nights ago had a low of 7 degrees. Our Aqua Hot continues to provide very nice coach heat, basement heat, and engine preheat before we fire up to leave. No leaks. This unit is so dependable.
Mountain Aire34
Greenlawn, NY 11740
Posted: 02/01/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again to all who responded. Narrowing moho search with
all info to all posts I have made in past. Once again THANKS TO ALL.
sharbra
Nevada
Posted: 02/01/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
An additional benefit of hydronic heating, is you have full coach heat while traveling without having to run the generator.
Ames
South Central Florida
Posted: 02/01/08 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Specifications are available at Aqua Hot
We have had two very minor leaks in 10 years and it was a connection fault and a $4 radiator cap that needed replacement.
They changed coolant requirements a few years ago from green anti-freeze to the pink stuff.
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
