RV.Net Open Roads Forum: Tech Issues: Snow chains on which wheels
 > Snow chains on which wheels
richccc
CA
Posted: 02/04/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
My tow has four wheel drive or I should say all wheel drive. I have chains for two wheels. Which ones should I put them on. If I had only four wheel drive I think I would put them on the rear wheels. I was wondering if I could damage my all wheel drive putting them on two wheels.
Richccc
08f450psd
Westminster, Maryland
Posted: 02/04/08 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I don't think you're supposed to ever put chains on the front of vehicle. I would imagine it would reduce steering control. Let's see if any one knows for sure.
smkettner
Posted: 02/04/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I would put them on the primary drive axle first, probably the rear.
Also there is generally more clearance in the rear with less stuff to damage.
Mousefart
New Jersey
Posted: 02/04/08 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Rear wheels
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
scottykrug
Aurora, CO
Posted: 02/04/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Ok, I'll bite- why? (rear wheels)
Seems to me that if they were in the front, they would help with steering and braking, especially on a 4wd.
"It's a dog eat dog world, and I'm wearing milkbone underwear." Norm
weasel4
Alberta
Posted: 02/04/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
richccc
Front wheels. With chains your not going to be speeding so steering shouldn't be a problem. And the front wheels will have the added weight of the engine on them giving better traction. JMHO from years of 4 wheeling for fun in Northern Alberta, snow,mud and muskeg.
BTC
Everything in moderation, including Sobriety.
kaagee
Burlington Ontario
Posted: 02/04/08 11:47am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't use them at all. you could damage the drive train.
ALL four wheels have to be the same circumference on all wheel drives..
mikim
Rancho Cucamonga, CA USA
Posted: 02/04/08 11:51am Link  |  Quote  |  Print  |  Notify Moderator
The reason you should not put wheels on just the front is that when you brake the brakes only apply on the front wheels unless you brake hard.
When you apply the front brakes with chains then the back of the vehicle will loose traction causing the vehicle to spine from the back. That is why some states, like Idaho, will not allow studded snow tires on only the front of the vehicle but mandate on all 4.
PAWildcat
Temple ,PA
Posted: 02/04/08 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I think if we knew the kind of vehicle, that could change some answers. Some vehicles don't have the room for chains on the steering wheels. There are straps made to be used like chains that would be a better chaoice for certain areas. That said, I don't think I would put chains or straps on a steering wheel. Too big a chance for damage on the steering axle if you would have problems with the chains coming loose or breaking.
2005 Ford F-250 PSD CC 4x4
2006 Forest River Wildcat 29BHBP
robbins
Sonora, Ca
Posted: 02/04/08 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Put them on the primary drive axle!
See 'ya on top
Keith
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
