RV.Net Open Roads Forum: General RVing Issues: Removing mold/mildew
 > Removing mold/mildew
dianerowley
Ohio
Posted: 02/08/08 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Ironically just today the RVer next to us started to replaced his vinyl trim. He discovered that the replacement strip that he bought was the incorrect size. Since he already had the trim off, he put it in a bucket with water and bleach. All the black spots came off and the trim is clean and pliable again. Need I tell you he just put it back on.
pcm1959
St Augustine, FL
Posted: 05/16/08 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
dirtengineer wrote:
This stuff will keep it from coming back, but might not take it off.
Concrobium
I buy it at home depot.
AWESOME stuff. It is also VERY good for removing odors. I have sprayed all the fabric areas in my fiver and it reduced the new odors dramaticly. I keep in the rv on hand all the time. PCM
Hornet28BHDS
Parker, PA
Posted: 05/16/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
It's not that hard to completely replace the trim.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
