Not a Clue
Southern Ca
Okay, all you expects out there
The ABS light came on in our RV.
It is a 2006 Ford E450 chassis with about 4500 miles on it.
We just had a US Gear unified brake system installed, but I
am told that it shouldn't have anything to do with the light
coming on.
Any ideas anyone? I know that there are probably serveral things.
But then I can maybe get some idea of the cost when I take it to
the repair shop. I also need a new chassis battery as the one we
have will not keep a charge.
Linda B.
2006 31' Fleetwood, TiogaSL - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
jameswb1
Danville alabama
ABS module is probably bad. Take it warranty work.
kaagee
Burlington Ontario
I had the same problem last summer...check out below...It was an easy fix....Good Luck..
Sorry, couldn't get the link to work!!
Anyway, I replaced the rear sensor..easy to do and the sensor cost about $25.00...
Ken
edited 02/08/08 07:55pm by kaagee *
T18skyguy
Eugene, OR
I'll bet Ford will deny your warranty when they see that modification. Aftermarket mods are the first thing they look for. Any excuse will do, it doesn't even need to be the system in question. Did US Gear put it in writing that it wouldn't void the warranty?
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
JB-ROO
Lawrence, Kansas
Check your Brake fluid level first.
JB
2007 F-150 S/C 4X4 5.4 Titan XLT 3.73 L/S gears TT package
2008 Sprinter Copper Canyon 252FWRLS 5th wheel
Ford Dealership Transmission Tech.
Retired wife
4 camping grand kids
90# chocolate Lab
othertonka
Stockton, CA
Clickable link to the above posters solution.
Click here
Link by Kaagee in above post
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Wherever I happen to park
Go to the REAR of the bus.
Actually, have someone stand in back of the motor home
Are the brake lights on?
ABS systems sense many things in your vehicle, they have hall effect sensors that sense wheel rotation, they read the position of the brake light switch
Should the switch fail.. Or should the brake lights fail, the ABS will fail
Should you accidently tear the wires off the wheel sensor.. It will fail (however in this case the light will come on when you start, go off when 20 seconds (or however long) later, then come back on when you start to roll) (Been there, Done that) they sense some other things too. Battery voltage being on the list.
Of course.. Module failure is also posssible
Not a Clue
Southern Ca
Thanks for all you ideas, it will be going into the shop on Monday, I guess I will find out then.
SAR Tracker
Sandy Eggo, Calif
had an ABS sensor wire get melted by an exhaust manifold... caused the light to come on. New sensor wire solved the prob.
LET US KNOW WHAT YOU FIND!!!!!!!!
Rusty & Cheryl & Serendipity (dog & Chief Security Officer)
2000 F150 4x4 5.4L/3.55 (108k miles and goin' STRONG!)
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
kaagee
Burlington Ontario
othertonka wrote: Clickable link to the above posters solution.
Click here
Thank you othertonka.. I couldn't get the link to connect!!
Ken
