RV.Net Open Roads Forum: Tech Issues: Manual shifting problem on new Chevy Diesel
 > Manual shifting problem on new Chevy Diesel
dennysbabe
La Quinta, CA.
Posted: 02/12/08 09:17am Link  |  Quote  |  Print  |  Notify Moderator
At the risk of sounding like a fool, I can't get my new 2008 Chevy 2500HD Diesel/Allison to shift with the "buttons" in the manual mode. I forget what the option is called, but when you put the gear selector down to "M" it comes up with a number from 1-6 to the right of the "M" and you're supposed to be able to manually shift by pressing the plus or minus button on the gear shift lever. I've tried doing it from a dead stop with the indicator showing M1, but when I take off and try to press the plus button to shift, it stays in 1st gear. Anyone out there have that option on their truck and can tell me if I'm doing something wrong or should I take it in for repair?
Screamingeagle
Pennsylvania
Posted: 02/12/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I hate to ask but what does the manual say?
Screamingeagle
2005 F350 6.0 CC LB Harley Edition
2008 Montana Big Sky 340
Me,him + the boxer boys--Harley and Brutus
SoCalTT'r
Posted: 02/12/08 09:30am Link  |  Quote  |  Print  |  Notify Moderator
The manual shift mode will NOT let you shift manually into the gears. When in the manual mode, the transmission shifts essentially the same as in the normal mode except the "top" gear it will shift up to is the one selected in manual.
2007 Silverado 2500HD CC/SB D/A
2005 Arctic Fox 25S, Hensley Arrow
TheFollands
Corona, CA
Posted: 02/12/08 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Manual Mode doesn't necessarily let you select gears. It allows you to HOLD a certain gear. This is usefull when towing to prevent the transmition from "hunting" for a gear when going up a hill.
2007.5 Chevy Silverado 3500 Crew Cab Dually
2009 Weekend Warrior 3905 SLC Dual Slide
2006 LTZ400 Quad (Dad)
2007 LTZ50 Quad (Son)
2007 Joyner 650cc Buggy (Wife)
1 Beautiful Wife
1 3.5yo Handsome Son
1 Spoiled Rotten Chihuahua
dennysbabe
La Quinta, CA.
Posted: 02/12/08 09:53am Link  |  Quote  |  Print  |  Notify Moderator
The manual says to do exactly what I described, but I thought maybe I was missing something.
Wilburg
Massachusetts
Posted: 02/12/08 10:00am Link  |  Quote  |  Print  |  Notify Moderator
ummmm, are your sure of what your talking about ..... why would there be plus and minus signs on the gear selector????
You can switch gears, I have done it in the higher gears, but not from first gear. Check the manual!
2007 2500HD CHEVY 4X4 LT2- 6.6 D/A Intergrated trailer brakes
Dual Cam Reese
2001 21' Sweetwater pontoon boat
2007 Keystone Passport 280BH
2008 Polaris X2 500EFI ATV
SoCalTT'r
Posted: 02/12/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
From what you describe, the transmission is responding as it is designed. When you are driving along and shift into manual, the "M" number that shows on the display is the gear the transmission was in when you moved the shift lever to manual. Once in the manual mode, the transmission will never shift to a gear higher than the one displayed. If you shift into manual at a dead stop, the gear and number shown will always be 1. If you were to "click" the display up to, let's say 4, while stopped, the truck will accelerate normally, shifting automatically until you reach 4th gear and then it will not shift to a gear above 4th. If you are driving along at 70 mph and then shift into manual, you will find that you are in 6th gear (unless you're climbing a hill or accelerating). If you then manually shift to 5, the transmission will shift into 5th. If you then bring the truck to a stop, and accelerate back up to speed, the truck will auto shift normally until you reach 5th gear.
SoCalTT'r
Posted: 02/12/08 10:32am Link  |  Quote  |  Print  |  Notify Moderator
One thing I should have pointed out is that when in the manual mode, the display does not show the gear the transmission is shifted into. It shows only the manual selection of the highest gear the transmission will shift up to.
Dale M
Calgary
Posted: 02/12/08 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi. On my 2006 D/A if I put put the gear selector in M it shows numbers from 6 5 4 3 2 1. If Im stopped and put it in M it shows
Im in 1st gear and if I start to drive it stays in 1st gear until
I press the + button on the gear shift handle to shift into 2nd and the same again up to 6th gear.. you can leave it showing any gear and then the tranny will shift up to that point but not further. if you have it in say 5th your truck will shift up and down normally but will only go as high as 5th gear.
Dale M
2006 GMC 2500HD D/A 4x4
2007 Wildcat 29RLBS
Hijacker 16k Slider
Prodigy Brake Control
Honda EU2000i Generator
Wilburg
Massachusetts
Posted: 02/12/08 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Dale M
This is how it works in my truck as well!
thank you for your post, I thought I was nuts!
