RV.Net Open Roads Forum: Tech Issues: furnace blower won't shut off
 > furnace blower won't shut off
YLSecret
Whitehall, NY
Posted: 05/28/08 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I am also having this same problem on my brand new 2008 Jayco Jayflight G2 31RKS travel trailer. The furnace blower will not shut off on it's own at all. It keeps running even after turning the thermostat OFF. (We tried replacing the thermostat, but that didn't work either). We turned the shut off switch at the blower itself, but the disables even the air conditioning unit as well. It can blow hot when you crank the heat up, but as soon as the thermostat read the correct temperature it turns the actual furnace off, but blower continues, thus cooling down the camper much quicker than it would normally.
This camper is now at it's seasonal site so it's makes it very hard to bring it to an actual RV repair place.
Any DIY suggestions would be greatly appreciated!
Thanks
pkunk
Questa, NM
Posted: 05/28/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like it could be the over temp relay. Read this.
http://blog.rv.net/2008/01/30/lp-appliances-flame-safety-devices/#comment-998
1989 Allegro, 30 ft., 454 CI 4 BBL, 3 spd.auto, 125gal.gas tank,85g.water & 85 grey &75 black holding tanks. 3-12v Optima 31m coach batteries
bigfootford
Fair Oaks, California
Posted: 05/28/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
rich&suehr03dbd, here is where you can get parts and read about the operation of your furnace. If you can look at the diagrams etc and have the ability you can fix it your self.
Bryantsrv home page
Bryant's rv write up on furnace problem
Bryantsrv furnace service doc's
Parts for your 8535
Diagrams and operation of Atwood furnaces
Hope this helps.
* This post was edited 05/28/08 09:23am by bigfootford *
94 F-250 ex cab,460, E40D tranny,airbags w/pump,bilstein shocks, 2000 Bigfoot 9.6 2500 camper, Progressive Dynamics 9260, Trimetric monitor and an eu2000i honda genny.
Wife and Molly- Ausie,Queensland healer
deciding
St. Paul, Minnesota, USA
Posted: 05/29/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Look on schematic for the low limit switch that controls when the fan shuts off. Might be part of the mother board or a seperate wafer switch.
