RV.Net Open Roads Forum: Towing: OE Wheel load rating
Search only in Towing
Open Roads Forum  >  Towing
 > OE Wheel load rating
Kathryn's Fate
Kansas
Posted: 02/16/08 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have the OE 16X6.5 Polished Forged-Aluminum wheels on my 2007 Classic 2500HD LBZ CCn4X4. There are some numbers stamped on it, some of which are:
GM C/N
959
4142
Superior
SF 1
T DOT
The tires are OE LT 245/75R16 load range E with 3042 lb rating.
I am thinking the 4142 may be the load rating per wheel, what say you?
Thanks.
2008 Carriage Cameo 32SB2
2007 2500HD 4WD Crew Cab Duramax Allison LBZ
2003 Cobalt 246 8.1 Volvo Penta Duoprop
2000 Suburban 2500 6.0 4.10
skipnchar
Topeka Kansas USA
Posted: 02/16/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Can't help with the numbers but....one thing is certain. They will be rated for MORE than the axles on your truck so unless you're greatly overloading the axles you won't have a problem.
Kathryn's Fate
Kansas
Posted: 02/16/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Skip.
Anyone know a good source to find out. I was at a tire dealer that suggested the 4142 number was it. They also called the dealer who told them it was 8600. I could call the dealer myself, probably will to see what they say.
Taboky
Nashua, NH
Posted: 02/16/08 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't really matter though. Your current tires already support more weight that your axle can. Most likely your rear axle is rated at 6k lbs. Higher weighted tires won't do much for ya.
Steve
'07 Raptor 3712
'08 F350 DRW Lariat crewcab longbed 4.10ls 4x4
'02 Kawasaki Nomad dresser
