RV.Net Open Roads Forum: A couple of ??? about installing two 6V batteries
 > A couple of ??? about installing two 6V batteries
Rich Panganiban
Southern California, USA
Posted: 02/18/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased two Costco 6V Golf cart batteries to replace a single 12v house battery. I have a couple of questions for you folks:
1. What's the best way to secure the batteries in the battery tray? The current battery is tied down with a nylon strap, is there a better alternative?
2. As far as wiring is concerned, can I use the existing cables? My plan is to hook the positive cable to the positive terminal of battery #1, and hook the negative cable to the negative terminal of batery #2. So I will need to purchase a length of cable to connect the negative trminal of battery #1 to the positive terminal of battery #2. Is this correct?
Thanks for your help.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
Kajtek1
CA
Posted: 02/18/08 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
My batteries just seat in the bay. I have only about 3" clearance, so they would not go far, but I never noticed them moved. Actually we have household chair in our coach, that stands unsecured under office desk and it never went out of this location neither.
For the connector you can use a piece of copper plumbing strap. That will make solid connector, interlocking both batteries and making them less prone to movement. Should be much cheaper, than heavy cables with made ends.
Piece of 1/2" copper pipe hammered flat might be even cheaper.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
wolfe10
Posted: 02/18/08 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
All your answers are correct.
In addition to the nylon straps, if the shelf the batteries are on leave room for them to move, use plastic-- like old cutting boards (lasts longer in battery acid) or wood (probably replace annually) to block them in.
Wiring:
House positive cable to positive battery #1.
Negative battery #1 to positive battery #2.
Negative battery #2 to house ground/negative.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
smkettner
Southern CA
Posted: 02/18/08 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
1 I bought my box from http://www.alliedbattery.com/boxes.htm
2 Yes, get down to WM or auto store and get a low cost battery cable with the lugs premade on the wire. Many lengths are available.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 02/18/08 11:24pm Link  |  Quote  |  Print  |  Notify Moderator
Using a solid connector is just asking for trouble, vibration alone will tear the post apart from the battery case, and for a trouble free way to stop a battery from moving, we have been using chip board plywood and the battery will never move, the 8 batteries I have are not strapped down and no movement in 5 yrs. Just my thoughts.
1998 34' Newmar Mountain Aire,210 Cummins Puller, 542 Allison 4 speed, BD Performance Exhaust Brake,BD Torque Convertor, Hendrickson Air suspension, 4 wheel disc brakes. 4-120 Watt 2-80 Watt Kyocera panels 8-T105s Golf cart batteries, Toad VW Jetta TDI.
Mandalay Parr
Phoenix, AZ
Posted: 02/19/08 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Might check with an auto parts store for various tie-down options. Your electrical connections are proper.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
Rich Panganiban
Posted: 02/19/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for the replies, I'll let you know how the installation goes.
