RV.Net Open Roads Forum: General RVing Issues: Vented Waste Valve Cap
 > Vented Waste Valve Cap
busch2fan
Wauconda, IL
Posted: 02/21/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
I just read an article in Trailer Life about a gentlemen who made his own "vented waste valve cap" - and he explained why:
He puts this on when he stores his trailer between trips and opens his black and grey tank valves so that air can circulate through the tanks and out the roof vents.
He claims it works wonders for keeping the tanks clean and odor free.
I just found one of these caps at Camping World:
Here's my situation:
I am a firm believer in the Geo Method and use it religiously. To date... no issues at all. But that doesn't mean I can't improve the process or care.
And question:
Is anyone out there using a vented waste valve cap? If so, whats your experience?
I can see both pros and cons...
Thoughts?
Thanks all... see you by the campfire!!
Jeff
2006 Ford F-250 FX4 XLT Crew Cab 6.0 Powerstroke Diesel
2007 Montana Mountaineer Edition 32PRD
ProPride 3P 1400 hitch (ordered)
See my modifications here!
swebber
Brunswick , MD
Posted: 02/21/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I have thought about using one but if the interior of the tank dries out then so does anything that might be stuck in there and then maybe causing a build-up of waste.
Will be interesting to see others replies.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
cruiserjs
Aurora, CO, USA/ Mesa AZ/ openroad
Posted: 02/21/08 09:52am Link  |  Quote  |  Print  |  Notify Moderator
No I always store my trailer with some water in all waste tanks to prevent drying out of whatever is left in and to keep the seals from drying out. never have had an odor problem in 15 years with fivers.
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2001 Silverado 2500HD shortbed
wonderful lifetime travelling companion/spouse
busch2fan
Wauconda, IL
Posted: 02/21/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
swebber - that is one of the "cons" I thought of....
cruiserjs - that is what I currently do as well...
Jeff
skipnchar
Topeka Kansas USA
Posted: 02/21/08 10:02am Link  |  Quote  |  Print  |  Notify Moderator
I'm betting he EVENTUALLY has clog problems with his black tank leaving it dry that way. Looks like one of those really BAD ideas to me. Black tanks should NEVER be stored dry. Good luck / Skip
plauterer
Manitoba, Canada
Posted: 02/21/08 10:06am Link  |  Quote  |  Print  |  Notify Moderator
What happens if Mr. Squirrel decides to build a nest in the tank and hauls in a bunch of twigs and grass? Or Mrs snake crawls into the tank and comes up the toilet when it is getting it’s first flush of the year? I will keep mine closed.
jay2003
San Joaquin Valley, California
Posted: 02/21/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Never thought of the seals before. I do the same though.. just a bit of water in the tanks with some valve lubricant (coconut oil) when storing to keep the valve from sticking for the next season. Don't think I would use one of the vented caps since the valve would have to be left open and could dry out quicker and get stuck in the open position.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
Doug and Cassi Glass
Clifton Forge, VA
Posted: 02/21/08 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
I keep some water and anti-freeze in mine in the winter. Even if I lived in the tropical south I'd keep my valves closed. I believe in rinsing good and keeping closed, after all it contains sewage and I don't plan to eat off it!
If rinsed good they won't smell unless you get right down there and whiff.
busch2fan
Wauconda, IL
Posted: 02/21/08 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in agreement with all of you... I'm currently doing exactly what y'all are doing.
Different strokes for different folks I guess...
I'll stick with the tried and true.
Mousefart
New Jersey
Posted: 02/21/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Seals drying out????
Unless you have a VERY, VERY old camper that has leather seals (like the old bicycle pumps), this is a non-issue.
The materials used to make dump valve seals do not "dry out". They are more likely to WEAR out or just plain break first. At about $7 each, it's not something I am going to jump through hoops for.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
