RV.Net Open Roads Forum: Adding a second 12v chassis battery, wiring ???
 > Adding a second 12v chassis battery, wiring ???
Rich Panganiban
Southern California, USA
Posted: 02/25/08 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
I just recent replaced my single 12V Interstate house battery with two 6V golf batteries. I would like to add the 12V to the existing one for the chassis. It's going into a Jayco Greyhawk Class C on the Kodiak chassis, so there is already a spot for the 2nd one.
My question is, what kind of wiring is involved? If anyone has done the same, I would appreciate a link.
Many thanks!
* This post was edited 02/25/08 11:17pm by Rich Panganiban *
bldrbuck
colorado
Posted: 02/25/08 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
To hook uo 2 12 volt batteries just add heavy wire from Pos to pos and neg to neg. That is all that is needed.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
smkettner
Southern CA
Posted: 02/25/08 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
Just get some battery cables from WM or autostore with the lugs already attached. Connect ++ & --.
12 volt side of life
Rich Panganiban
Posted: 02/25/08 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't know it was that simple, I thought some type of special switch was required. Thanks for the replies.
timsrv
Battle Ground, WA
Posted: 02/25/08 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
When batteries are wired together they really should be of the same type, size, and age. You can wire together for a short term advantage, but over the long term (unless the above conditions are met), it can lead to premature failure of one or both batteries. Tim
hotrod4x5
Fulltiming Southwest USA
Posted: 02/25/08 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
To further expand on what tim said, the older battery will drain off the newer one, as the two that are connected tend to equalize. However, if you are using them for the chassis, then they are only used to start the vehicle and run things like the radio, is that correct? Which brings up another question, is a deep cycle the correct type of battery to use in the chassis?
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
Rich Panganiban
Posted: 02/26/08 08:07am Link  |  Quote  |  Print  |  Notify Moderator
That's a great point. The existing chassis battery looks like the same one that I removed from under the house. I'll have to make sure before I do add the second one. If they are, they would have been pretty close in production date since they are the original ones when we purchase the MH last year.
