ru4nd2
Jesup, Iowa
I just made some leveling boards/ramps today. Chose to use 2x10's that were about eight inches longer than the tire span. Then made another set that are about four inches shorter than the first that way they act like ramps to help when driving up on. Also made a set out of 1x10's that are a little shorter than the second set. This should give a pretty good variety in leveling. I also made jack stand platforms for under the front jacks and rear stabilizers.
I added flexible side handles and end handles on the leveling boards to allow for ease of use when carrying them and pulling them out of storage. As well all of the leveling boards are interchangeable and can lock together so they don't pop up and move around when driving up on them.
Haven't had a chance to use them yet, but they look good and hopefully they work well.
javaseuf
Southern Cal
I made mine from Trex, a composit product used for decks. It is heavier than wood but doesn't warp, crack or absorb water.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Mansfield-Five
Mansfield, MA
I am researching ideas for making leveling blocks and this thread had some good ideas. If possible, please post a picture. Thank you.
2005 Frontier 2505
Reese dual cam sway & Prodigy brake controller
2004 F150 5.4L V8 4x4 with 3.73 axle wheel base 138.5
GCWR=15,000 GVWR=7,200
Jim102
Flower Mound, Texas
ru4nd2,
I like your idea and would like to copy it, but, can you post a picture?
Thanks,
Jim
2007 29' Maverick 292 DS
A 12 yr. old long haired Doxie, "Digger"..
tenbear
Northern Vermont, USA
When I had my TT I used 2 2 X 6s long enough to have both wheels on them. If you have boards too wide they will probably split when parked on uneven ground. Measure your tire contact width and make the boards about one inch wider. Plain old pine is good unless you plan to leave the TT on them in the off season. Long boards are good, you can put only one wheel on the board for half the lift, assuming tandem axles (what Dodge Guy's photo shows) don't try it with dualies.
2004/5 Four Winds Dutchman Express 28A, Chevy chassis
Subaru Impreza Outback
dodge guy
Chicago, western subs.
I have almost the whole right side of my front pass through storage compartment dedicated to leveling blocks. I use PT deck boards for side-side leveling and I have a big assortment of PT 8" 2X4`s and 4X4`s for the stabilizer jacks and tongue jack! they can also be used for side-side leveling if the site is that bad! much better than having the Leveler blocks, which would be expensive if I bought enough to cover for the wood I use now!
Wife kim
Son brandon 6yrs
Daughter marissa 5yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
Wherever I happen to park
I won't tell you what to carry, since I'd need to look at your tires to be sure
But I can tell you I recently downloaded a manual from Mitchelin
Michelin
I very strongly suggest you download the "Tire Guide" off this site
It is, of course, specific to Michelin tires when it comes to tire charts (which are included) but the "how to" which includes how to use leveling boards is generic, works for all tires, all brands.
PattieAM
Maryland
I too recommend the Lynx Leveling blocks - storage bag, 1" per block, easy to clean, don't decompose or get funky, and not slippery. Available at Walmart - under $50. last time I checked.
martipr
Haltom City, Texas
Dick_B wrote: I vote for 2 x 10's but also 1 x 10's when 2" is too much correction.
The boards should support the entire width of both tires (assuming tandem axle) and the 10" width makes it easier to pull forward or back onto them.
A 2 x 10 is 1 1/2" thick. A 1 X 10 is 3/4" thick. My parking place at home is quite a slope and 2 2 x 10s give me exactly the 3" I need.
2007 29' 27FBV Trail Bay V Series
2007 Dodge Ram 1500 Mega Cab 5.7 V8
Husky WD Hitch with Reese Dual Cam
qtla9111
Monterrey, Mexico
This is the one I made a couple of years ago. It works great, has three different levels. I painted it and glued coarse silica sand to it.
1998 Nissan Pathfinder
2004 Shadow Cruiser 18ft.
Living and Boondocking Mexico
