RV.Net Open Roads Forum: Class C Motorhomes: 2008 Jayco Seneca 34SS
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > 2008 Jayco Seneca 34SS
Irish34SS
Colorado
Posted: 02/28/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
I just got schooled by Jayco on the codes above the visor relating to the springs. I then found a 2008 Medium Duty Truck Online Order/ reference Guide to confirm. The following is fact:
HD1 is the 15,000lb axles
GN2 is the 19,000lb springs
That being said my 08' I ordered at the end of 10/07 and picked up 02/08/08 did in fact come with the 19,000lb springs.
taviking22
Omaha, NE
Posted: 02/28/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Glad you already have the upgrade springs!!
I did a walk-through in a Seneca last fall with my local dealer...love at first sight! I retire in 3 years and have my crystal ball aimed at a Seneca. I'm jealous of you!!
Enjoy your new rig!!
taviking22
Omaha, NE
2006 2500HD Silverado 4 X 4, Duramax LBZ
2008 Tracker Pro Guide V-16 Boat
2009 Jayco Eagle Super Light 28.5 RLS 5th Wheel
iparky
temecula, california
Posted: 02/28/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
you state what the codes are for those axles and springs , but what are the codes for the other axles and springs and what are thier ratings. that would help us determine what we have if different.
mfa
Posted: 02/28/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Start at this web page...
country1nphx
Phoenix
Posted: 02/29/08 01:33am Link  |  Quote  |  Print  |  Notify Moderator
good info, thanks
Irish34SS
Colorado
Posted: 03/02/08 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Here you go:
Front Axle-
FM7..7,000LB
G38..8,000LB
FM8..8,000LB
Front Springs-
FK6..7,000LB (INCLUDES STABILIZER)
FSN..8,000LB
F15..9,000LB
F59..STABILIZER BAR
Rear Axle-
HD2..DANA S110 13,500
HD1..DANA S130-S, 15,000LB
HPK..DANA 19060S, 19,000LB
G80..REAR LIMITED SLIP
NW9..ELECTRONIC TRACTION CONTROL, UTILIZING ABS
SPQ..QUIT-RIDE SPRING PACKAGE
Rear Tapered Leaf Springs-includes shock asorbers
GXA..13,500LB
GQ0..15,000LB
GN2..19,000LB
GS4..REAR STABILIZER
EV8..REAR SUSPENSION BRACKETS ARE RIVETED TO FRAME IN LIEU OF BOLTS
EV9..BOLTS IN LIEU OF RIVETS
The EV codes becomes significant if you plan to add a rear sway bar. It takes the labor to 9-10 hours=$$$$ with the EV8. I have the 8
GVWR-
GZJ..18,000LB
GZG..19,500LB
GZH..21,500LB
GW2 or C4I..22,000LB
GW4 or C6V..26,000LB
I will have to go visit where mine is stored first to see what I have regarding everything but the rear axle and spring.
Have a Great Day!!
iparky
Posted: 03/02/08 10:46am Link  |  Quote  |  Print  |  Notify Moderator
thanks, that will help all out!
