roadking2005
Tyler, Texas
Pulling a 27' trailer with an Equilizer hitch, with an 07 Tundra.
If i am just staying overnight and can get reasonably level with putting a "little" lift on the front of the trailer via the jack while still staying hitched up .... is that too much pressure on the truck or the trailer??
Thanks for any thoughts or experience you might have.
Rick
Ggardner
Gardendale, Alabama
I almost never un hook for a one nighter. I have Sierra Denali truck pulling 34 ft. Flagstaff. Never had a problem.
skipnchar
Topeka Kansas USA
No more pressure sitting still than when traveling. AS long as you've level no problem but watch the weather. I stayed hitch one night with stab jacks down, water and electric connected and a tornado warning in the middle of the night left me WALKING (well running) a mile to get to the shelter because I couldn't move the truck. Good luck / Skip
Bob Vaughn
Seffner, Fl.
That is taking the weight off the back of the truck and shifting it to the front and to the trailer wheels.....I do this all the time and have done it for about 30 years with no adverse affects.....It speeds up the time to get ready to get underway the next morning....
colochoclab
Arvada, Colorado
For quick overnight stops, I sometimes will not unhitch. It really depends on the terrain I'm parked on, and if I can get the TT level without unreasonably lifting the back of the truck. A few inches in okay, anything more and I'll unhook.
-Lab
Skip: Did you really have to go runnin' one night??? Dang. That's scary. (I hate tornados!)
2004 Nissan Titan Crew Cab 4x4 w/ Off-Road & Big Tow
2006 Jayco JayFlight 29FBS
Equal-i-zer Hitch
Prodigy Brake Control
Member of clubtitan.org
"Hershey" the Chocolate Lab (Co-Pilot)
"I asked God for a true friend. He sent me a Labrador Retriever."
SuperDutyMan
Western PA.
I do that sometimes when the weather is really questionable,put my blocks under tires for side to side leval and if I am close on tonque height i'll crank it to leval,unplug my harness as some brake controlers pull a little to light indicator light,and just let it sit that way all weekend,as far as my WD it's no different than towing for 3 days,besides usually you need to raise tongue which unloads your WD bars.
2008 Keystone Cougar XLite 29RLS
2006 Super Duty V10 6 Speed 4.10S Tow Command Tow Pkg. 4X4
roadking2005
Tyler, Texas
thanks for the comments
y'all just saved me some occasional work and time
rick
skipnchar
Topeka Kansas USA
Don't want to steel the thread...check your PMs / Skip
Roadtrippin
Pennsylvania
I'll leave it hitched but drop the front legs to take the weight off the truck.
2003 Dodge 2500 RAM 4X4 Quadcab Cummins High Output
Banks Six-Gun/Speedloader/Pyro,Trans Temp,and Boost gauges. Mag-hytec covers.
2006 Cedar Creek Silverback 5th Wheel (31LBHBS)
Hornet28BHDS
Parker, PA
A one nighter won't hurt anything! Have fun!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
