RV.Net Open Roads Forum: Travel Trailers: Have to unhitch??
 > Have to unhitch??
robbins
Sonora, Ca
Posted: 03/04/08 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, leave 'er hooked up. Put down a couple of jacks to make it more stable. No problems.
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
pete42
Jamestown, Ohio
Posted: 03/04/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
I leave mine hitched and I don't put down any jacks.
No different than hooking up the night before I leave for a trip.
Trailer may wiggle some just like at truck or rest stops.
PrivatePilot
Courtice, Ontario, Canada
Posted: 03/04/08 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
For a one nighter where I don't plan to unhitch I'll usually just drop the rear stabs so they just barely touch the ground, and then lower the tongue jack to the ground and lift ever so gingerly - this not only stabilizes the front, but shifts some weight onto the rear stabs and makes things rock solid.
Be carefully you don't lift the front too much if you use my method as you can easily damage some of the lighter stab jacks if you crank the tongue jack enough that you shift massive amounts of weight to the back end.
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD.
Checkout my blogs, adventures, and more here!
Mark
Vapor_Trails
Yucaipa, CA
Posted: 03/04/08 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Add me to the list of staying hitched overnight. If it's two or more nights I usually travel off somewhere so I do unhitch and level it up proper.
68 Me & DW
93 DD
03 DD
06 F150 Screw 6.5' Bed, 4x4, 5.4, 3.73
04 Tahoe 23RB-GL
Honda EU2000 Parallel Cables
"I hope you like Guinness, Sir. I find it a refreshing substitute for...food." Col. Jack O'Neill, Stargate SG-1.
Turbo Diesel Dude
Green Mountain, NC
Posted: 03/05/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Make sure that your battery doesn't get drained. I usually unhook my electrical unbilical cord. Learned my lesson on a ferry from Newfoundland. Killed my battery so bad, had to buy a new one in Nova Scotia,
charles weidman
symbasden
WI
Posted: 03/05/08 06:31am Link  |  Quote  |  Print  |  Notify Moderator
When I do this I don't mind leaving trailer weight on the truck, but I try not to put truck weight on the trailer jack. So if I have to raise the front more than just taking the weight off of the truck I will unhitch quick. I don't even pull forward, just un-do the coupler and raise up the trailer. In the morning it is a quick drop on the ball. I don't want to overload the jack...
Jeff
2009 Rockwood Signature Ultra Light 8317SS
2004 Dodge Ram 1500 QC LB Hemi
DW Kelly and DD
junmy3
Warner Robins GA
Posted: 03/05/08 06:50am Link  |  Quote  |  Print  |  Notify Moderator
DW and I are going to a state park later this month. We will be in one spot the first night and a different spot the rest of the stay. If we are close to level in the first spot, we will not unhitch. We have stayed at a couple of rest stops and did not unhitch. We do disconnect the power cord to make sure the truck battery does not get drained.
Jim & Junnie
2005 Sunline Solaris T-2553
Our Web Site
Kistler
Oro Valley, AZ, United States
Posted: 03/05/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I also stayed "hitched" and hopefully am in a site that I can raise the tongue a little to get level; I am afraid my Expedition will develop a permanent squat
I don't unhook the electrical umbilical. I thought there was some switch or something built-in that would not allow TV battery drain....
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Airstream Classic 25' (7,500 lbs. loaded)
2003 Expedition EB 5.4L, AWD & AdvanceTrac
Class IV tp/Prodigy/Dual Cam
missouguy
Springfield, MO USA
Posted: 03/05/08 07:57am Link  |  Quote  |  Print  |  Notify Moderator
skipnchar wrote:
No more pressure sitting still than when traveling. AS long as you've level no problem but watch the weather. I stayed hitch one night with stab jacks down, water and electric connected and a tornado warning in the middle of the night left me WALKING (well running) a mile to get to the shelter because I couldn't move the truck. Good luck / Skip
Just pull the safety pin on the receiver and drive away, everything else will stay with the trailer. Just don't forget the safety chains.
Frank
Frank & Gail
'02 F250 SD CC SB 7.3 TD 4X4
2001 Sunnybrook 33BWS Big Slide
dodge guy
Chicago, western subs.
Posted: 03/05/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I stay hitched when possible. the only draw back is if you need to get out real quickly for some unfortunate reason, you will have to unhitch or unhook from the utilities.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
 > Have to unhitch??
