gusco01
Gallup, NM
Anyone bought the Saf-Tee tire monitoring system & do you like it? Also the new Doran 360 system can you change the batteries yourself or do you have to send back & pay $50.00 each to change the batteries. Thanks in advance for your response. Dan
creeper
Richmond Hill, Georgia
Stay far away from Saf-tee. They charged a lot of people's credit cards and delivered no product. I had to dispute the charges after receiving no product after a month.
Blog and projects page
See Profile for more pictures and links
Link Exchange
gusco01
Gallup, NM
OK what about the Doran 360. Can the end user change the batteries or do they have to send back to factory and charge allot to replace? Thanks Dan
marvmarcy
Polson, MT, USA
Talk to a good, honest Pressure Pro dealer to get the straight answers. I recommend Mike McFall (pomcfall@gmail.com). It doesn't cost nearly $50 to get new batteries, and the batteries should last around three years. I have a PP system monitoring 14 tires and it is wonderful.
I learned with my old Tire Sentry system why Pressure Pro doesn't have do-it-yourself battery changes. The Tire Sentry had reliability issues, mostly related to using batteries that weren't quite "direct replacements". I had to buy batteries from Tire Sentry to get the system to work. Don't even consider Tire Sentry.
I've no experience or comments on Saf-Tee.
JMHO
Marv
2001 Volvo VNL42T420, ISX450/1650, super 10sp w/GearMaster
2003 Newmar Mountain Aire 38RLRK
Piaggio MP3 400 scooter
RVing since 1979 - Fulltime since 2000 (mostly CO, MT, NC & Key West)
Retired USAF
vic46
Red Deer, Alberta, Canada
Check with these folks for the Saf-Tee system. Tweety has a good rep, I believe. - http://www.tweetys.com/
Question relative to the "new" doran system will be capably and promptly answered if addressed to Debbi - gerdes_deborah@doranmfg.com
Vic
gusco01
Gallup, NM
Doran 360 batteries question. I guess I answered my own question. I called Doran they called me back today. Batteries supposed to last 7 years, Lithium batteries. To replace you have to mail back to Doran & pay 29.95 each wheel unit if you still have your receipt, if not then its 49,95 each. I also asked where the unit is built, ya you guessed it China. So I guess I'm going to buy a China build tire pressure monitor to monitor my China built tires, Makes since to me. All I have read so far looks like a good system, I will probably by one, Dan
Airstreamer67
Pineville, LA USA
I don't really know how long a PressurePro battery lasts. Does anyone have a system where the batteries have failed? Is it really three years compared to Doran's claimed seven years?
It seems funny that PressurePro would allow such a disparity, since lithium batteries, if that is the difference, are easily obtainable by PressurePro too.
Btravelen
N. IL
I believe Pressure Pros sender battery life is 4-5 years, at which time you send it in for replacement for the cost of the battery alone. The senders are are also smaller and lighter than the Doran, which may expiain the difference in battery life.
Take Care
2000 Ford Excursion V10 (SOLD) 2005 Exc. 6.0L PSD, 2wd, 3.73LS, Air Lifts with Load Controller II, towing '00 31SKS Holiday Rambler Alumascape with a '01 Hensley.
K5OIT
Conroe, Tx
And one final point; the Pressure Pro system is made in the USA!!!
Good luck, safe travels and happy camping!
02 F250 7.3 Auto CC LB Brakesmart Reese Straightline
98 Sunnybrook 29DBS
rbguinn1
El Paso
Are Saf-Tee Tire Monitoring System back orders been filled by their distributor- www.truckerpartstore.com? Reportedly, back orders are being filled now!! Truth or fiction??
If you have received the new smaller sensor Saf-Tee system, what are your initial experiences and observations in using this system??
