RV.Net Open Roads Forum: Fifth-Wheels: What to use to re-attach slide seal?
 > What to use to re-attach slide seal?
KampingKris
Folsom, CA USA
Posted: 03/07/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
The dealer re-glued and said it wouldn't come loose, but it did.
It's too far to the dealer for this simple fix...
It's on a track on the side of the slide and it just moves up and down. Needs to be attached again.
What kind of adhesive can you use with rubber seals?
Thanks
KampingKris,FiremanSteve,DaughterCara
Jada - American Eskie princess
2003 GMC Sierra 3500
2006 Alpenlite Limited 34RLR
Greengiant
Harrison, MI
Posted: 03/07/08 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Kris, I used a white silicone adhesive made by Dow Chemical, I bought it at a RV Dealer.
Greengiant
Dave H M
IL
Posted: 03/07/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Kris
I had tha problem with my last camper. The dealer always just got me down the road
One of the cures i read about but traded the ole bomb off before trying was contact cement. A guy swore by it. I know that stuff is amazing.
He recommend appying in the usual way of doing both surfaces and waiting the prescribed time and then do the stick em together act.
But like I said, I have not tried it.
frogkisser
TEXAS
Posted: 03/07/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I use 3M brand made for rubber seals. I haven't had one come loose using it.
WM has it.
