RV.Net Open Roads Forum: Fifth-Wheels: Changing a tire
 > Changing a tire
ru4nd2
Jesup, Iowa
Posted: 03/07/08 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
Just wanted to see what everyone was carrying in the event of a flat tire? Ramps, jacks, tire iron, electric impact, etc?
Shotgun
CA
Posted: 03/07/08 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
AAA card
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
BobsYourUncle
Surrey, BC Canada
Posted: 03/07/08 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
Real short hydraulic jack and a star wrench.
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Check Out My Rebuild Project (Updated June 15, 2006)
Project Feedback
smkettner
Posted: 03/07/08 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
Torin 2 stage 2 ton jack This unit will get under the axle with the tire flat and still have enough lift.
Tire iron in the truck fits fine. Jack goes just fine under the axle U-bolt.
lc51willy
Fulltime USA
Posted: 03/08/08 12:02am Link  |  Quote  |  Print  |  Notify Moderator
Good Sam (ERS) Emergency Road Service. I am Good Sam Life Member for 10 years.
Larry
USA TRAVELER
LC&KC
MOJO (Deceased 4/10/06)
2000 International 4700 CREWCAB 530 power/Full Air ride cab.
JAKE BRAKE/ Gvwr 23,500
40ft. Prowler AX6 4 Slides/Trail Air Pin Box/HughesNet dish (
Love Boat II
Some where in the USA
Use Good Sam Emergency Road service..
Why carry all that heavy stuff and do all that work .
For less than $100 a year
Captain T. Love (Ret.)
Retired Airline Pilot
CB Chanel 13
AMERICAN AND PROUD OF IT
I WANT MY COUNTRY BACK
BUY USA MADE
http://sagebrushpatriot.com/america.htm
Golden_HVAC
Fulltime, CA, USA
Posted: 03/08/08 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If you ever tried to lift a 11,000 pound axle with a 3 ton jack, then you will understand why I have a 6 ton jack. Each pump of the jack moves it slower, but it is easier to push down the jack handle on a higher tonnage jack for a given weight, because of the mechanical advantage of the jack.
Yes I have road service, and IF I ever broke down in town, across the street from someone that can fix my RV, I might give them a call. But it seems every flat tire has happened about 85 miles from someplace, so I just keep changing them myself.
What I recomend everyone carry is at least a spare tire - mounted is better, but even unmounted if it is a 19.5" or larger, that is good because a road service can install a tire they have in hand, but not one that is 200 miles away or out of stock.
I also have stainless steel wheel trim rings, and they require a special 1-1/16" socket to remove them. Not to special, unless you are 100 miles from town and don't have one!
I also have a deep 7/8" socket and a 24" long wrench required to torque it to 130 foot pounds. 19.5" and larger tires require even more pressure, so the AAA card will come in handy.
I also put down my leveling jacks just to "Level" the RV, not to lift the tire off the ground, that would be hazardous. But taking off 5,000 pounds from the rear axle helps when jacking it up, and the RV does not shake as much when big rigs go by at 65 MPH!
It also helps to have some towles to clean up, and a few gallons of water to take a shower - if required. If it is raining, then rain gear (but that has not happened to me yet).
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
Locomotiveman
Willmar, MN
Posted: 03/08/08 12:11am Link  |  Quote  |  Print  |  Notify Moderator
A 'low profile' 20 ton hydraulic jack, couple of 1foot 2x12 boards, 3/4" drive breaker bar and extension w/right socket for lugnuts.....and an aired up spare. TOM
Locomotiveman..Yes I am a career cross-country Locomotive Engineer. Wife is an RN. We are CLOSE to retiring and 'downsized' to a Monaco Executive w/450hp Cummins and nice drapes. Locomotiveman
larry barnhart
wenatchee. wa usa
Posted: 03/08/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
We carry an 8 ton bottle jack. Just lifting the axle doesn't mean the whole trailer is on the jack. Do it at home and see what is needed. Waiting for service isn't always very fast but depending on your health and where the problem is on the road makes good sense to call AAA. chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
tom_kat
way upstate new york/lake george area
Posted: 03/08/08 10:46am Link  |  Quote  |  Print  |  Notify Moderator
short 12 ton jack and blocks and all the tools and cheater bars to change a tire.and a good sam ers card.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
 > Changing a tire
