RV.Net Open Roads Forum: Travel Trailers: Running Lights
 > Running Lights
TWhaylen
Colorado
Posted: 03/11/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Can someone put it out on the table a "how to" for doing this through the use of the plug that normally goes into the TV?? I only ask because I think that it would be a good way to check your bulbs from time to time. Thanks
2005 Surveyor SV234
2004 F-150 Supercrew Lariat w/5.4L/3.73 Gears
Voyager Brake Controller
Reese Friction Sway Bar
symbasden
WI
Posted: 03/11/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
I had mine on once but then decided what's the point. I don't mind them, it actually looks neat on some rigs. Flashing rigs in the desert is fine, but I'd rather not see them in the campground, same thing with the scare lights I guess
Jeff
2009 Rockwood Signature Ultra Light 8317SS
2004 Dodge Ram 1500 QC LB Hemi
DW Kelly and DD
busch2fan
Wauconda, IL
Posted: 03/11/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
TWhaylen,
If your TV is wired the same as mine (and it should be), as you are looking into the plug that is attached to your camper, hold it so that the locking tab (that the rcvr lid locks onto) is at 12 noon. If you insert a wire into the the hole directly at the top center... and then the other end of that wire into the hole that is next to that hole in a clockwise manner... BINGO... your lights should light up.
Hope this helps.
Jeff
2006 Ford F-250 FX4 XLT Crew Cab 6.0 Powerstroke Diesel
2007 Montana Mountaineer Edition 32PRD
ProPride 3P 1400 hitch (ordered)
See my modifications here!
TWhaylen
Colorado
Posted: 03/11/08 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
busch2fan wrote:
TWhaylen,
Hope this helps.
Jeff
Thank you for the help. Can you use any gauge of wire or does it have to be a specific type of wire? I assume when you are talking about that "locking tab" you are pointing towards that little area of the plug that is molded out so that it isn't a perfect circle?? Do you just pull the wire back out to turn it off? Thanks
busch2fan
Wauconda, IL
Posted: 03/11/08 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I used some 1" long pieces of some 3-12 Romex I had laying around the garage. It works good since its a solid wire... easier to push in the plug. But I've known people to use anything. You shouldn't have to worry about overloading it... people use a 5amp fuse... just about any wire will work.
Correct on the tab thingy... didn't know how to describe it. LOL!!
And lastly... yes. Just push the wire in = LIGHTS ON. Just pull the wire out = LIGHTS OUT.
Hence the reason why I've only used little pieces of scrap wire...
I inevitably lose the wires. Long evening... plenty of cold beverage... bed time rolls around... put out the campfire... finish the last beverage of the evening... pull out the little wire for the running lights...
Next morning... can't find the little wire.
On REAL BAD mornings... can't find my pants either... but that is a story for another day...
Enjoy!!
Jeff
TWhaylen
Colorado
Posted: 03/11/08 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the help Jeff!! I assume then that the lights end up running off your TT battery? does this pull a lot of power from the battery or is it so slim that it shouldn't even cross my mind when they are on?
busch2fan
Wauconda, IL
Posted: 03/11/08 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, they're running off of the battery... but since you're connected to shore power - you're also charging the battery - so it's a wash. In my case, once MOD I did was switch all my running lights and tail lights to LEDs so the power draw is even further negated.
Like I say... myself and our camping group have done this for years with no issue.
If you weren't hooked up to shore power... then I would think it becomes a consideration.
If you're hooked up to shore power... run 'em... emjoy 'em... and crack open another beverage!! LOL!!
Jeff
LeeShearer
Royersford, PA
Posted: 03/11/08 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Built my own cube. Two way switch for on or flash.
2005 Fleetwood Resort EXT 25SB
1999 Chevy K3500 short bed dually
 > Running Lights
