RV.Net Open Roads Forum: Tow Vehicles: Differential Lube for 03 Chevy 2500HD?
Search only in Tow Vehicles
 > Differential Lube for 03 Chevy 2500HD?
Cox89XJ
Tennessee
Posted: 03/08/08 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
What brand and type gear lube do "yall" suggest? It was changed at the stealership around 20K or so. It has the locking differential. How many quarts for the rear and front also?
DCopp
Kennewick, WA USA
Posted: 03/09/08 01:21am Link  |  Quote  |  Print  |  Notify Moderator
For the rear axle, I changed the grape juice at 500 miles to Mobil 1 75w-90. I haven't changed the front axle lube.
The owner's manual will give capacities.
'03 Chev 2500HD LT 4WD D/A CC SB
'03 Desert Fox 21SW Toy Hauler
'02 HD Road King, CRF230, TTR125, 2-DR125's, CRF100, PW80
16,400 GCVW
Dave/Jenn/kids
All work and no play makes Dave a dull boy
JustLabs
Washington State
Posted: 03/09/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I used Mobil 1 75w-90 in both diffs on my '01. I wasn't about to pay what the GM dealer wanted for their synthetic.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
AUWing
Slinger, WI
Posted: 03/09/08 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for Mobile1 - Go to Dieselplace.com and look for an oil comparison in the fluids section
From someplace in SE Wisconsin
2006 Silverado 2500 Ext-cab / reg box / D/A
2006 Jayco Eagle 325BHS
2001 Goldwing, Cyclemate trailer and a tent (to remind me why we have the Jayco)
1999 BMW 1200C (007 bike) too cool to part with
LIKE2BUILD
Mt. Zion, IL
Posted: 03/10/08 10:16am Link  |  Quote  |  Print  |  Notify Moderator
The GM Gov-lock (G80) does not use clutches, so no friction modifiers or additives are necessary. Mobil 1 75W90 or 75W140 (if you tow really heavy) should work just fine.
KJ
2002 Jayco Qwest 324G
2004 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
1981 Seastar 18' Runabout
1996 Polaris SLT780 Waverunner
3 Wonderful Sons (9, 3, & 1 year)
1 forgiving wife!!!
Dogarms
California
Posted: 03/10/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I've used both Mobil 1 75W-90 and Redline 75W-140, which I run now, in the rear. I have Redlin 75W-90 in the front. Both brands, among others are excellent.
TC
'03 GMC ExCab, SB, Duramax, Allison, 4x4, Husky mudflaps, Procaps, Bilsteins, Leer shell, BedRug, Oilguard Bypass,
Caterpillar fuel filter, ISSPRO EV Pyro and Boost guages, Titan V, Equal-i-zer EQ1400, Arctic Fox 30U
BenK
SF BayArea
Posted: 03/10/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Make sure you check the manual for the fluid spec, as most OEMs today have
special formulations. I think to get folks to 'have to' go to the OEM parts
counter, but that is just my thoughts on that. Most after market suppliers
will over time, match those spec's but that may take a couple years or so.
The Eaton G80 (GM option code is also G80) locker does use 'clutches' as the
locking mechanism. Clutches but they do not 'slip', much.
Here is the link to a previous thread on this topic, but that embedded link does
not contain the same info as before. Eaton has removed the content for some
reason. Here is the link to the thread on this board:
http://www.woodalls.com/cforum/index.cfm........d/12563693/gotomsg/12587045.cfm#12587045
and the text from that thread:
Go to Eaton site and read up.
Here's link: http://automotive.eaton.com/product/traction_stability/lockingdiff.html
Seems no one really wants to use the hot link, so here's the text below.
It is a locker, the manufacturer says so.
Availability
¨ Standard Equipment on Dual Wheel 3500 Series trucks.
¨ Optional Equipment (G80 Order Code) on all GM two-wheel and four-wheel drive light trucks and sport utilities.
Benefits
¨ Improved traction differentiates the vehicle relative to other rear wheel and four-wheel drive vehicles on the market.
¨ Functions as a limited slip differential during normal driving conditions; provides full axle lock when needed.
¨ Maintenance free; requires no lube additives.
¨ Enhanced towing and off-road performance.
¨ Patented carbon friction disc technology enhances performance and durability while reducing warranty claims.
Principles of Operation
¨ Wheel speed difference (left to right) in excess of 100 RPM will cause a flyweight mechanism to open and catch a latching bracket.
¨ The stopped flyweight will trigger a self-energizing clutch system, which results in the cam plate ramping against a side gear.
¨ Ramping increases until both axles turn at the same speed (full lock), which prevents further wheel slip.
¨ At speeds above 20MPH, the latching bracket swings away from the governor and prevents lockup from occurring.
Technical Specifications
¨ Automatic locking takes place within a fraction of a second, so smoothly that it is unnoticed by the average driver.
¨ Unlocking occurs automatically, once the need for improved traction is gone, and is unnoticeable to the average driver.
¨ Compatible with anti-lock brake systems.
-Ben Picture of my rig
