RV.Net Open Roads Forum: Hybrid Travel Trailers: Awning Accessories Suggestions
Open Roads Forum  >  Hybrid Travel Trailers
 > Awning Accessories Suggestions
winty03
Minnesota
Posted: 03/10/08 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
We are looking to purchase of accessories for our Roo 233 and wanted some opinions on tie downs and deflappers. We were looking at these toe downs.
Awning Tie Downs
and these deflappers
Deflappers
Are either of them worth buying and or needed? Thanks for the input.
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 03/10/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Our last Jayco had a Carefree awning with built in awning deflappers, only used tham about 6 times in 2 years. Never had to use tie downs, we just would retract the awning is the wind came up! Our newest Jayco we had to buy awning deflappers, like the ones you looked at, and only used them once is 3 years. We almost always srow the awning when we're not there, so never lost one due to high winds or rain!
ram96
Port Matilda, PA
Posted: 03/10/08 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have and use both when every we are out. I did change the rope to rachet straps.
It only take a minute to put the on and then I don't have to worry if a quick storm blows up.
03 ram 1500
R-Vision C191
nny12972
NY
Posted: 03/10/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
If I'm leaving---I roll it up.....if it's flapping, I roll it up...
J
CAMPinMI
Michigan
Posted: 03/10/08 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Tie downs Wal Mart $9.99. You really want the deflappers that are wider, like the chip bag closer thing-a-ma-call-its......JMO
winty03
Minnesota
Posted: 03/10/08 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Campinmi what deflappers do you recommend? I was liking the tie downs because they attach to your awning roller and they pull down/out on the roller to keep your awning taught and rolled out.
CoachmenKen
Jackson, NJ, USA
Posted: 03/10/08 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
I use the same deflappers and find they work well. I do 3 on each side. I use a slightly different tie down setup, though I don't see it for sale anywhere now. Mine has springs on the end that hold a 2 inch wide strap that goes up and over the awning tube. The springs are held to the ground by those screw in stake things. Cheap insurance in case something pops up while we're not around
* This post was edited 03/10/08 03:59pm by CoachmenKen *
Ken, Dawn, Rebecca,our 2 Goldens, Penny & Tucker
2001 Coachmen Santara, 3602 KS, F53 (purchased 7/04)
2002 Ford Explorer XLS, Falcon 2 Tow Bar, Brake Pro
FMCA Member F350314
Good Sam Member
States we have visited and camped in
winty03
Minnesota
Posted: 03/10/08 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about these?
awning tie downs
Gaffer222
Northwestern CT
Posted: 03/10/08 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
awning tie downs
We us those (from Camping World) but use our own ratchet straps instead of the ones provided. Much easier
2004 Ford Explorer - V6 w/Tow package
Equalizer & Prodigy
2005 EZ190 Keystone Zeppelin HTT
DW, DD Circa 2002, DD Circa 2005
My Webshots
djdetrick
PA
Posted: 03/10/08 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have used the Camco deflappers as per your link on the awning of our 233 Roo for the last 3 years and have found they do a good job.
Dave
2006 Rockwood Roo 233
2007 Ford F150 Super Crew
Dave
DW DS DD
2007 Ford F150 Supercrew 5.4L Triton
