rj0105
Logan, Ut
We put industral velcro in about 4 places on bottom. It sticks well, Had trouble removing to take in house for winter. Then for travel, we place a pillow between slide and TV and another behind. No problems so far.
2003 Chev 2500HD D/A LT CC SB
Amsoil Air Filter
Frantz Oil Cleaner/Filter
1998 Sunnybrook M630RKF 5er
happycampersweare
lincoln park michigan
just got a new fiver that has a flat 19 in.and it has a bracket that holds it to the ET center but I'm not sure if I will trust it to hold TV when going down the road
03 dodge 2500 5.9L diesel
2008 35ft.Denali 31sbbs-m5
paztruck
San Diego, CA
We have storage under our bed and put our 20" under then with a blanket wrap. Now that we upgraded to a 26" dvd combo I lay it at an angle between the bed and wall wrapped with the blankets and pillows. It travels well there.
2006 F250 Extended Cab, Long Bed, 6.0 PSD, Tow Package
2006 Keystone Springdale 242
happycampersweare
I'm also looking at upgrading to a 26in. I 'am wondering if the bracket on the one I have now will fit a new one anyone know if these are universal?
desert.girlie
AZ
In our travel trailer we only have/had a tv stand so we would unhook it and place it on the bed, under the pillows, when travelling/in storage.
catadjuster
Amarillo, Tx
Here is what I did with mine and have had no problems during many miles of travels over some rough interstates.
Bedroom TV. Screwed the bracket into the metal wall stud.
Mounted 32" HDTV over the opening where the old 27" was.
Mounted on a piece of plywood hinged on one side. Now have much additional storage for DVDs and Games. Can also swing it out to see from the table.
Storage and access to connections.
04 Crossroads Silverado SF36MK, 5th Airborne pinbox
04 Dodge Quad Cab Long Bed 5.9 HO
Banks Monster Exhaust, Firestone Ride-Rite Air Springs
Fulltime
National Catastrophe Insurance Adjuster.
Home is anywhere at any time. Currently in Niagara Falls Area
happycampersweare
Caladjuster,how did you put your 32in. on the plywood did you use a bracket that screws into the back of the tv?
happycampersweare
by the way great pictures !!
5th amendment
yale mi
my wife and i both believe the same way
no tv
34' liberty
07 2500 dodge 5.7
six speed manual 3:89 rear end
Sportchassis_RV
Georgia
catadjuster wrote: Here is what I did with mine and have had no problems during many miles of travels over some rough interstates.
That looks like a great solution. We have been thinking about what do do in our 5th-wheel and I think you have just solved our problem.
Thanks for posting those great pictures.
Michelle
2008 Newmar X-Aire 40CKSH
2007 Freightliner SportChassis RHA 114 330 hp/Mercedes Benz
2003 Ford Excursion Limited 7.3 l PSD (hers)
