RV.Net Open Roads Forum: Buying Hitch locks / Wheel locks in Canada
 > Buying Hitch locks / Wheel locks in Canada
69RoadRunner
VA
Posted: 03/27/08 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
http://www.tirelock.com/product.php?cid=1
Does it have to be from The Great White North?
09 Newmar Ventana 3942
richardcoxid
Idaho Falls, ID
Posted: 03/27/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
If you really want wheel locks,try this-
Assuming that you have a single axle tent top trailer, looping a piece of chain through a hole in one wheel rim then around the axle/spring then connect both ends with a padlock. For a dual axle trailer chain both wheels on the same side together.
If you are concerned about a bolt cutter cutting the chain, heat treated chain is available at most home inprovement centers/hardware stores.
Remember that most thief protection devices are of a delaying nature, when seconds/minutes count, thieves won't spend a lot of time when stealing something.
1998.5 Dodge, 24V, auto, 3.54, 2wd. BD Exh. brake. CB, Prodigy Brake Controller, Aero 60 gal. tank. 200,000 miles
1998 Hitchhiker II, mod#31RLBGBW, RBW L'tl Rocker Hitch, Generac NP50 G generator. Dexter EZ lube 7,000# axles with 8,000# capacity brakes
vcorkett
North Vancouver
Posted: 03/27/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
I think so, I've looked at quite a few US websites and the shipping costs just rule out buying from the US.
