RV.Net Open Roads Forum: HWH Jack Springs - Where to Buy?
 > HWH Jack Springs - Where to Buy?
Beach Boy
Birmingham Alabama
Posted: 03/21/08 05:21pm Link  |  Print  |  Notify Moderator
I called HWH on 3/19 and got the springs on 3/21. I bought two pairs of springs for $30 plus $10. I would recommend HWH to anyone.
Bill & Laura Blanton
1999 Coachmen Catalina 34' FW with Two Slides
Lug_Nut
British Columbia, Canada
Posted: 03/21/08 07:43pm Link  |  Print  |  Notify Moderator
Ditto on HWH. You probably will not find a better supplier than them. Great people.
'13 Newmar King Aire 45' ISX 600
newxmar
East Otis, MA
Posted: 03/21/08 09:07pm Link  |  Print  |  Notify Moderator
Sounds like salt air started stress corrosion cracking on the highly loaded spring wire.
Suggest that in your environment the new springs receive a coat of read lead primer and then a finish coat of black. Probably a spray can of each would do the job. Don't believe the factory finish is all that great for a salt atmosphere. At least more paint won't hurt.
Also believe HWH has made some spring design changes, Don't know when or what models, but you may receive improved springs.
Pirate
Northeast Tennessee
Posted: 03/22/08 05:39pm Link  |  Print  |  Notify Moderator
I came out one day and found three of my springs broken. Not coincidence IMO, probably a bad batch. I wasn't too happy at having to replace them all but HWH made it better by sending me all the replacements I needed at no charge. They weren't that old.
Beach Boy
Birmingham Alabama
Posted: 03/26/08 01:14pm Link  |  Print  |  Notify Moderator
The springs that I received were .5" shorter and tapered at both ends. I called HWH and said they redesigned the springs. They said they are better.
As for the salt air, I am going to do as suggested. Thanks.
rmartin6821
Van Buren Arkansas
Posted: 03/26/08 09:35pm Link  |  Print  |  Notify Moderator
I bought a set of front springs for my Tiffin from a local dealer when one broke as I was raising the jacks. Cost was 12 dollars. Putting it on was a different matter. Since I had a torn rotator cuff, I let the dealer put it on. There was one young man there on a Saturday morning and he worked for an hour before he finally got it on. Jack did not fully retract and he tried to push it in with a floor jack and then used a large screwdrive to get the hook on the spring in the jack. If there is an easy way, I would sure like to hear how it is done.
Pirate
Northeast Tennessee
Posted: 03/27/08 04:58pm Link  |  Print  |  Notify Moderator
I hooked mine up to a come-along, pulled them out a bit, and put in several wood shims. That kept them long and made it real easy to just put them back on. Had to use a small bottle jack under the jack pad to push up on the low side which leveled out the jack pad. Or, get your fat beer drinking bozo of a brother in law and have him hang from the jack spring and put it on that way.
Beach Boy
Birmingham Alabama
Posted: 03/27/08 05:17pm Link  |  Print  |  Notify Moderator
rmartin6821 and Pirate,
Do you have the fold-down or the straight-down jacks? I have the fold-down and was not anticipating any problems? It sounds like you had a difficult time.
Bill
rmartin6821
Van Buren Arkansas
Posted: 03/27/08 10:06pm Link  |  Print  |  Notify Moderator
I have the straight down jacks.
Pirate
Northeast Tennessee
Posted: 03/28/08 08:05am Link  |  Print  |  Notify Moderator
straight down.
