RV.Net Open Roads Forum: Tech Issues: Onan--oil dripping out of filter case
 > Onan--oil dripping out of filter case
TinkerMan
Refugio,Texas
Posted: 03/15/08 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Onan 4000 and appx. 150-hrs on it. After running around 10-hrs oil will be dripping out of filter case. I ran it with oil level right on full and then tried it running oil at half way between full and add oil mark. No change. Would appreciate thoughts on problem . I haven't hooked up a Manometer to the crankcase yet but plan to unless you'll have a quicker solution.(change oil every 50-hrs.)
ONAN Microquiet 4000 Genset---Mode 4KYFA26100k----Spec K----Rpm 3600---s/n F040655308
Thanks,
Frank
Gale Hawkins
Murray, KY
Posted: 03/15/08 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Is the filter just defective or just loose assuming it is the typical spin on type? I would try to tighten it tigher and if that did not fix it I would just spin it off and spin on a new one.
MrTravelDecal
wandering
Posted: 03/15/08 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
What filter case? As far as I know 4k microquiets and microlites do not have a filter....
Like old travel decals? me too!
The reason talk is cheap: because supply exceeds demand
K3BH
Slower Lower Delaware
Posted: 03/15/08 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't think your generator had a filter. Regardless, I found something the other day that may be relevant.
I checked my oil level and it was down a little. I put the "dipstick" back in, remeasured, and the oil was where it should be. The next time I checked, I noticed the oil level slowly rise back up after I took the dipstick out and was holding it in my hand.
Apparently the unit builds up pressure in the crankcase that needs to be vented for the oil to be at the correct level. This doesn't make a lot of sense to me, but I was sure I saw it rising back up in the oil filler hole.
Jay
Jay, Susan, 2 cats in Bigfoot 29G 6.0L Diesel. Toad Honda CR-V
Jim4455
Wherever I choose
Posted: 03/15/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Another item to check is the low-oil-pressure switch. Mine was leaking from this, replaced the switch and everything is ok.
1993 Winnebago Vectra 33' 454 Chevy
2002 Saturn LW200
Blue Ox hookup
kg5388
memphis
Posted: 03/15/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
By the filter case do you mean the air filter housing?
The 4.0KY has no oil filter as it has no oil pump and as such there is no oil pressure switch or sending unit some units has a low oil level float switch in the back of the pan.
If the oil is leaking out the air filter or the hose from the top of the valve cover that runs to the air cleaner housing then you are running to thin weighted oil or the oil breather valve under the valve cover is sticking.
There was a problem with the valves setting to deep in the slot
1995 viking pup
1988 four winns 160 freedom boat
Onan RV full service certified
level 2 onan industrial gen tech
comfortguard APU full service certified
onan portable full service certified
onan RV hybrid full service certified
TinkerMan
Refugio,Texas
Posted: 03/16/08 01:55am Link  |  Quote  |  Print  |  Notify Moderator
I apoligize for the mistake which I typed. I am referring to the Air Filter Housing which is dripping the oil and also I use the Onan Oil which is sold for these engines. Again thanks for the replies.
Frank
