RV.Net Open Roads Forum: Travel Trailers: Furnace starting by itself
 > Furnace starting by itself
La_Bolt_Fan
Los Angeles, CA
Posted: 03/17/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
This is my first TT. During the "Cold" months here in Los Angeles, when I leave for work in the morning and the temp is in the low 30's, I notice the furnace is operating. On warmer days (above 35), it is not. Is this normal, some type of anti-freeze function? Also, on the last trip I took, it was in the 50's in the morning and the fan was running when I woke up, but no heat. Is this a defect??? Thanks!!!
Backpacking one week, RV'ing the next!
PrivatePilot
Courtice, Ontario, Canada
Posted: 03/17/08 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Your thermostat will not only have a temperature setting, but should have another switch for "On/Off".
If left in the on position, even with the temperature setting at the far lowest end it could still be commanding the furnace to start.
Toggling the other switch to the "Off" position will completely lockout the furnace no matter what the temperature. This assumes, of course, your trailer is winterized and having the interior drop (potentially below freezing?) won't cause any harm.
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD.
Checkout my blogs, adventures, and more here!
Mark
La_Bolt_Fan
Los Angeles, CA
Posted: 03/17/08 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks PrivatePilot,
There is only one slide with a click on the left. I made sure is was clicked, mystery!!
hotrod4x5
Fulltiming Southwest USA
Posted: 03/17/08 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
If the fan is running and no heat, it either means you are out of propane, or it is at the end of the cycle and just running out the warm air without the burners going. Most likely the out of propane reason.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
