RV.Net Open Roads Forum: Fifth-Wheels: Getting the gas hot water heater working
 > Getting the gas hot water heater working
NorthernNeck,VA
Montross, Va.
Posted: 03/21/08 11:08am Link  |  Quote  |  Print  |  Notify Moderator
My wife and I just purchased a 2005 King of the Road Royal Villa. We are taking it out for the first time this weekend. The electric hot water heater works with no problem. My question is how do I get the LP gas to run the hot water heater???
Jimmy & Kathy
Northern Neck, VA.
2008 GMC
2005 King of the Road "Royal Villa" 34BW
M GO BLUE
Southgate, MI
Posted: 03/21/08 11:11am Link  |  Quote  |  Print  |  Notify Moderator
With it being a 2005 I would assume there is a separate switch for the electric as well as the gas...
Can you tell us more concerning why the gas is not working? (pilot lighting? any clicking? gas turned on and flowing? propane tank full?etc)
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS
Built-In Onan 5500W generator
NorthernNeck,VA
Montross, Va.
Posted: 03/21/08 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I know both tanks are full. I don't know how or where to light the pilot light (or if I even have to light it). The heat is working so I know the gas is flowing.
Screamingeagle
Pennsylvania
Posted: 03/21/08 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Make sure you have LP in your tanks and that the valve is open. There will be air in the gas line that may take a little time to purge. You have a gas ignitor switch with a red light on it. Turn this switch on and the ignitor should automaticly light the water heater. You can switch off the electric to do this. You will know when it lights by looking outside your rig where the water heater exhaust is. You will be able to hear it burning.
Screamingeagle
2005 F350 6.0 CC LB Harley Edition
2008 Montana Big Sky 340
Me,him + the boxer boys--Harley and Brutus
Tvov
CT
Posted: 03/21/08 11:35am Link  |  Quote  |  Print  |  Notify Moderator
When we first get to a campsite and set up, to purge the gas lines I turn on the stove top burners for a minute or so. This seems to clear out any air in the lines and then the refrig and water heater seem to work fine.
2008 F-250 CrewCab 5.4L,
goin2themountains
Aztec, NM
Posted: 03/21/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it may take a minute or two to purge the gas line, but also might suggest, along with the switch inside for the gas hot water, there is also a switch on the heater itself (lower left hidden behind about everything on mine) that needs to be set for the gas ignition to come on.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
CS_Grill Crew
Discovery Bay, Ca
Posted: 03/21/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
This certainly is good practice. We do this before we leave home and when we set up. We also run water in the shower for a few minutes to remove any trapped air in the water lines as well. The water heater should have electronic ignition so no need to mess with the pilot if I am correct. It should also know when to switch from gas to electric and vise versa. You may have an auto switch that is on electric. Did the manual for your particular unit come with it?
32 Winnebago Adventurer: Shreks Ride...
Luv to fish? Check out www.coastsidefishingclub.com
NorthernNeck,VA
Montross, Va.
Posted: 03/21/08 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I've checked the manual and couldn't seem to find anything. I have one switch on the wall above the kitchen sink and then another one in the box where my slide buttons are. They both will glow red when I turn them on. I guess I just need to figure out which one is which.
hyattjlbb
Minot, ND
Posted: 03/21/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have had this happen before, as stated above you probably have to purge your lines (or unpurge). Run the stove top burner(s), let it run a minute and then try to light your water heater. Should be fine after that but if not back to square one. Hope this works for you!
2007 Jayco Jay-Flight 31.5BHDS
2006 Chevy Silverado CC/SB 2500HD, Duramax/Allison
Beautiful Wife of only 12 Years
Boy - 10yrs
Boy - 4yrs
Snow Dog
Regina, SK Canada
Posted: 03/21/08 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have switches on you control panel where you read the tank levels? If you do there will be one that says water heater pilot. Turn it on. The yellow light will come on and then go off. It goes off when the pilot lights. To turn off the heater, turn off the pilot switch. Hope this helps.
1998 Dodge 3500 dually turbo.
1999 Nu Wa Snowbird Legend 31 + 2 RLTGBW
1998 12' Porta-Bote with 5HP Nissan and Electric motors
2 X Honda 2000EU
Years and years of experience to gain!!!
