RV.Net Open Roads Forum: Travel Trailers: Hitching made easy now.
 > Hitching made easy now.
JaycoRickJoan
Rogers, AR
Posted: 03/21/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
I use the hitch-up mirror. Just used it for the first time this past weekend. Works slick, but the convex mirror can be a little deceiving. It may appear that the hitch and ball are aligned, but you can be an inch off and not know it until you get out and look. I think I will buy some of those florescent stick on dots at Wal-Mart, place one on top the ball, one on top the hitch, and that may help align better. Those dots are cheap enough that if they wear off from the hitch moving around, you just replace it with another.
Either way, it is a marriage saver.
Rick & Joan
Rogers, Arkansas
2005 32ft Jayco Eagle TT
2005 GMC Sierra 2500HD
Terryallan
NC
Posted: 03/21/08 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Lining up ain't my problem. I can tell where the hitch is by looking at the TT in the mirrors. Get both the same and it lines up. Distance is my problem
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
Peg Leg
Anderson, IN
Posted: 03/21/08 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sound like you have an excellent back up plan. First use on Memorial Day weekend, if it don't work - bury it.
KA9ATV
K2500 7.4 3.73
Michelin 245/70R19.5 XDS2 on Vision Type 81's
31' Dutchmen
Yamaha EF3000iSE
retired gadgetman
pete42
Jamestown, Ohio
Posted: 03/21/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
I use the "back up, get out, turn wheel, back up, get out, pull forward, look for help" method. A camera, a mirrow or rods would be nice.
yesitsfree
Central Ohio
Posted: 03/22/08 04:23am Link  |  Quote  |  Print  |  Notify Moderator
Paula&Chance wrote:
I have the hitch aligner that has yellow (looks like tennis balls) mounted on top, they are magnetic. One attaches to truck and other to hitch on camper. They telescope up to a height that is easy to see no matter how high your truck bed is.
It works great and with the same principle as the pictures you show. I can hitch up in less than five minutes now, instead of 49 times of backing up and getting out of truck to look and doing it over and over again.
I bought my set at Cabela's online.
Yes this is what my dad bought us. Glad to hear they work well. Won't be able to test them till Memorial weekend.
H & E
North Texas
Posted: 03/22/08 05:15am Link  |  Quote  |  Print  |  Notify Moderator
I have a set that I used for a utility trailer but with bulldog hitch and coming in at an angle they did not work well. Grease on magnet after use is messy. Bought a camera and it works much better. Hooked the camera to the parking lights instead of back up and can check things while driving. I am thinking about painting the TT hitch white so I can see better in dark area.
sMohrs
Whitehall, PA
Posted: 03/22/08 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a set of magnetic hitch allignment w/tennis balls on top from Herbor Frieght for $10. I'll use those when my son is not with me. When my 9 year old son is with me, he helps and gets me under the hitch the first time every time.
Pete Mohr, Whitehall, PA
'97 Suburban 454
'06 Jayco Jay Flight 29FBS
Jayco 29FBS Mods
BillB800si
S.E. MICHIGAN
Posted: 03/22/08 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Yes, Harbor Fright has them for $7.49 and when we get back to Michigan I'm going to get a set of them.
Look here;
Hitch Alignment
Happy trails
Bill B. (Michigan)
2007 Dodge Ram 2500 MegaCab CTD
2007 Jayco Eagle TT Model 322FKS
summutt2002
(somewhere in the mountains of Utah)
Posted: 03/22/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, Burbman.....I've got the same problem. I use the frame to line up and I only have to get out a couple of times...not bad. Couldn't we use one of these alignment devices and just open the barn doors when we hook up? Might try it.
As of 7/14/08.....'01 Excursion Ltd 7.3L PSD (not yet tricked up...maybe never)
'06 Prowler 260RLS, Equal-i-zer, Prodigy..and 3.1 dogs
