GMC/Chev offer an IBC. For $200 (it has to be ordered as an option - can't be installed later) it is far better then the Prodigy I used to use. I have to say, when adjusted properly, there is no trailer lag or trailer braking too early. The whole thing stops as a unit.
Carriage Cameo 33CKQ | 08 GMC 3500HD CC LB Duramax Dually | Sam the Cat and the Labs | Best wife going
The OEM integrated brake controllers on GMCs don't work with the new electric over hydraulic brakes. So be sure of the braking system on your trailer before ordering the option. I got the integrated brake controller on my new 2008 GMC and am now in the process of installing a P3 to handle the electric over hydraulic brakes on my new Titanium 5th wheel. Apparently from the problems that the installing is having with the installation it's not a simple process to install the new controller and by pass the OEM item.
Streamlite 22FB Owne wrote: The OEM integrated brake controllers on GMCs don't work with the new electric over hydraulic brakes. So be sure of the braking system on your trailer before ordering the option. I got the integrated brake controller on my new 2008 GMC and am now in the process of installing a P3 to handle the electric over hydraulic brakes on my new Titanium 5th wheel. Apparently from the problems that the installing is having with the installation it's not a simple process to install the new controller and by pass the OEM item.
The GM doesn't work with Dexter E/H brakes and the Ford doesn't work with Carlisle E/H brakes. Exactly opposite for which one does work.
Go figure?
2001 Sea Breeze fiver. National Built one Heavy Pig! Heavy is good, right?
1999 F250 4X4 PSD CC LB HandshakerFalcon Weather
