RV.Net Open Roads Forum: Fifth-Wheels: slide leak
 > slide leak
obrn59
Jacksonville, FL
Posted: 03/22/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I noticed there was water on the carpet on either side of the slide when it is extended after a rain. Does this mean the slide seal is bad?
I'd appreciate any advice.
Steven, Lesa and Taylor
2004 Potomac 5333RL
F350 Dually 4X4
cruz
Prescott, AZ
Posted: 03/22/08 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Mine leaked on one side of the Bedroom slide. I found that the rubber seal on the outside did not seat right after extending the slide. It was tucked under at the very bottom on that side. Just stuck my finger under the seal and ran it down to the bottom gently pulling the seal back out. It worked, and now it seats correctly every time. not sure what the deal was, but hey ... simple fix.
Cruz
HR & Beth
2006 Chevy Silverado LT3 3500HD, DRW, D/A, CC, LB, 4x4 and RED
2008 Jayco Designer 35RLTS
Cassie - pure Black Giant Schnauzer
Mollie - pure White Mini Schnauzer (the boss)
obrn59
Jacksonville, FL
Posted: 03/23/08 05:58am Link  |  Quote  |  Print  |  Notify Moderator
I'll check that out next time. I'm really dreading having to replace any seals. The wetness was on both sides of the slide on the carpet. It's happened twice.
Rawhyde
Ohio
Posted: 03/23/08 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Mine just did the same thing while in Daytona a few weeks ago.
Same problem and fix as cruz. No big deal, all is fixed now.
PaulandTammy
Elk Creek, Ky
Posted: 03/25/08 02:20am Link  |  Quote  |  Print  |  Notify Moderator
Mine leaks when the water runs along the bottom rail of the slide. The corner of the seals overlap there. I just put a piece of tape on the bottom of the slide rail lip (both sides ) and the water drips off the tape. No more wet floor.
PaulandTammy
2006 D3500 4x4 Cummins 6 spd DRW
2009 Cardinal 362 BHLE
 > slide leak
