TWhaylen
Colorado
So I am going to be picking up my new to me TT here in the next week or two and I am wondering about if I need to do anything with the tire pressure on my TV before towing. The TT that we got is about 24' in length and has a dry weight of about 3,500 lbs. Normally I just put in about 5psi below what is stated on the door of the the truck. I know on the actually tire it has a max psi of much greater. So in all I think I normally have them set about 35 psi. Am I going to need to worry about adding more air than that for towing or should I be okay with that setup and my TT size and weight? Right now I have the factory BFGoodrich Rugged Trail T/A 275/65/R18 tires on the truck. Thanks,
2005 Surveyor SV234
2004 F-150 Supercrew Lariat w/5.4L/3.73 Gears
Voyager Brake Controller
Reese Friction Sway Bar
4Kings
NE Missouri
What is the maximum pressure of your tires, that's what I would run.
2003 Chevrolet 2500HD, CC, SB, 6L, 4.10, Auto, 4x4
2005 Wildcat 27BHWB, RBW 15K, Prodigy, TTT Mirrors
troll3193
SouthWest, MI USA
I have a lot heavier truck and TT, but I typically air my TV up to max sidewall pressure of 80psi (I have e-rated tires)... The sticker on my door calls out 55psi unloaded and 60 front/70 rear loaded....
When I had my 1/2 ton TVs I always ran the tires at max pressure when pulling... Also ran LT tires (d-rated) not passenger tires...
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
robbins
Sonora, Ca
Run the max that is stated on your sidewalls.
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
TWhaylen
Colorado
Well I went out and looked and the tire even stated that the max PSI is 35 and each tire stated that the max load is 2,601 lbs. So I guess if I just put in the 35 I should be fine??
BarneyS
S.E. Lower Michigan
My tires are E rated with 80PSI max stated on the sidewall of the tire. I always tow with front at 75# and the rears at 80#.
Barney
2004 Sunnybrook 30FKS TT
Hensley 1400# hitch
2002 Ford F250, 7.3L PSD, SuperCab, Short bed, Auto, 3:73rear
1996 Harley Davidson FLHRI Road King
Check out the new RV.net Blogs!
Visit our website here
troll3193
SouthWest, MI USA
TWhaylen wrote: Well I went out and looked and the tire even stated that the max PSI is 35 and each tire stated that the max load is 2,601 lbs. So I guess if I just put in the 35 I should be fine??
Are the passenger tires (P) or light truck tires (LT)???
I would guess with the 35psi max, they are passenger tires maybe?? A D-rated LT tire would have a max pressure of around 60-65psi.
Bryan
TWhaylen
Colorado
Bryan
I as well would assume they are passenger tires.
skipnchar
Topeka Kansas USA
robbins wrote: Run the max that is stated on your sidewalls.
BINGO - That's your answer
mowermech
Billings, MT
skipnchar wrote: robbins wrote: Run the max that is stated on your sidewalls.
I must disagree. The idea is to have the tread of the tire flat, for even wear. I would follow the tire pressures given on the data plate or the Owner's Manual. If you are running at maximum load for your tires, then you should have the pressure noted on the sidewall. For anything lighter than max load, your tire tread will be bulged in the middle, which will increase the wear in the middle of the tread, and lessen the contact patch, resulting in less traction. Less traction will induce more slippage, resulting in even greater wear.
I find that following the truck manufacturers recommendations on tire pressures gives me better traction and increased tire life, not to mention a better ride.
However, to each his own. Ultimately, the decision is yours.
Good luck.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
