Anyone know where the relay which turns off the TV power when the ignition is turned on is physically located in a Jayco Seneca HD 35GS. I just can't seem to locate it and haven't been able to find it in the threads. Thanks for your help.
Look in the fuse pnnl. and locate that fuse and pull it out. I f you can't find the fuse there is probably a plug in next to the one that is on the inter-lock. If it is not a real big deal to get to it you can just plug the tv into the one next to it.
take the cover off of the vcr and look for the wires coming out of the plug box. cut the purple wire that resembles a door bell wire and marrette the ends - problem solved
Could I assume this will also work for an 08 36fs? I was looking at having to run an extension cord to the outlet and run the generator to keep kids and momma happy.
I can now confirm that the 2008 36FS has the same purple wire running from the outlet in which the DVD/TV plug into. I cut the wire and now the family can watch movies on the go. Life is great and this is just another reason to love RV NET!
Does this apply for a Coachman Leperchaun 32 footer? Just wondering if the answer to the interlock relay was universal to all RV's?
Got the same problem.
