RV.Net Open Roads Forum: Class C Motorhomes: TV Power / Ignition interlock relay
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > TV Power / Ignition interlock relay
5etechsupport
South Florida
Posted: 03/26/08 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know where the relay which turns off the TV power when the ignition is turned on is physically located in a Jayco Seneca HD 35GS. I just can't seem to locate it and haven't been able to find it in the threads. Thanks for your help.
CISCO8325
Escondido, Ca.
Posted: 03/26/08 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
follow your tv power plug and it should be part of that plug. somewhere in this forum they explane how to bypass it.
dennis16002
Butler, Pa, USA
Posted: 03/26/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
It has a 5 amp fuse in the fuse block that operates it.
DHS
bilco55
Kansas City
Posted: 03/27/08 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Look in the fuse pnnl. and locate that fuse and pull it out. I f you can't find the fuse there is probably a plug in next to the one that is on the inter-lock. If it is not a real big deal to get to it you can just plug the tv into the one next to it.
overbudjet racing
guelph ontario
Posted: 03/28/08 04:39am Link  |  Quote  |  Print  |  Notify Moderator
take the cover off of the vcr and look for the wires coming out of the plug box. cut the purple wire that resembles a door bell wire and marrette the ends - problem solved
Rich Panganiban
Southern California, USA
Posted: 03/28/08 11:53am Link  |  Quote  |  Print  |  Notify Moderator
It's in the outlet the TV is plugged into. Open it up and do what overbudjet racing said. Works great!
Dakzuki
Carnation, Wa, USA
Posted: 03/28/08 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Who wants a TV in an RV?
95 Chinook Premier
crop guy
Monroe, Georgia
Posted: 03/31/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Could I assume this will also work for an 08 36fs? I was looking at having to run an extension cord to the outlet and run the generator to keep kids and momma happy.
crop guy
Monroe, Georgia
Posted: 04/20/08 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I can now confirm that the 2008 36FS has the same purple wire running from the outlet in which the DVD/TV plug into. I cut the wire and now the family can watch movies on the go. Life is great and this is just another reason to love RV NET!
rbanuchi
Boca Raton
Posted: 04/20/08 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Does this apply for a Coachman Leperchaun 32 footer? Just wondering if the answer to the interlock relay was universal to all RV's?
Got the same problem.
If anyone knows, let me know!
Much Appreciated!
Rob
