RV.Net Open Roads Forum: Travel Trailers: 7 pin plug & dielectric grease?
 > 7 pin plug & dielectric grease?
Chris&Lori
Lilburn, GA
Posted: 03/26/08 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Need a little help here.
I used dialectric grease on my 7 pin connector and it crystalised around the charging wire pin.
Should I not be using it on this connector?
Is there a better corrosion inhibitor designed for this type of application?
Chris, Lori and the Greyhounds
94' Dodge Ram 2500 4X4 Cummins T/D
05' 30' Coachman Capri
Campinfan
Washtenaw County, Michigan
Posted: 03/26/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure because I have used it and never had a problem. I would be prone to trying it out and seeing if it works. I think it would work fine. Hope someone knows better than me.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
Trailer Trash 2
Santa Fe Springs, CA
Posted: 03/26/08 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have never put anything on my plug for years and it works perfact all the time. I would clean it up with a dremal wire brush and leave it dry.
It works for me.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
1996 Ford F-350,Clydesdale, 7.3 Turbo W/Banks
Pulling a Super Fine Montana 2980RL
skipnchar
Topeka Kansas USA
Posted: 03/26/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I don't use it on mine but I really can't think of any reason it would harm anything. Wonder if you might have had a loose connection that was arcing and causing the problem?
CaLBaR
Ontario, Canada
Posted: 03/26/08 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use it regularily on two TT and have never had a problem. After winter I need to clean it and then re-apply but that is about it. It keeps my connector and plug clean and rust free even with all the salt here in the Southern Ontario winters.
2007 Rockwood 8298 SS
2006 GMC Sierra Crew Cab 5.3 V8 3.42
Draw-tite Max-E-Loader Hitch
HP Dual Cam Sway Control
Prodigy Brake Controller
Chris&Lori
Lilburn, GA
Posted: 03/26/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I wasnt sure if maybe there were current or heat limitations on dielectric grease.
I didnt see any signs of arcing in either plug or receptacle and it did seem like it was heat related. I recently replaced the truck receptacle a while ago because of corrosion, so I guess now its time to look at the trailer plug end... it probably has some hidden corrosion too somewhere.
chi6488
florida
Posted: 03/26/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I use it for all my electrical connections on my boat and it works great inhibiting corrosion.
2009 Jayco Eagle 324BHDS
2008 F250 King Ranch 4wd
2005 GLacier Bay 2670 Cat
opnspaces
San Diego Ca
Posted: 03/26/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I think dielectric grease is the correct stuff to use. You might have to get some electrical contact cleaner and wash the old hardened grease out. then just replace it with new grease and go about your happy way.
1996 Suburban 4x4. 350 Vortec, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup. 980 Lbs dry
It's so small I forget it's back there.
swebber
Brunswick , MD
Posted: 03/26/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I use the spray cleaner that Radio Shack sells and have had no problem in three years.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
MM49
Brighton, MI, USA
Posted: 03/26/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
The correct service for this connection system is WD40 and compressed air. Spray WD40 on both halves of the connection and blow off with compressed air. Do this several times a year. More if you are in the northern climates.
MM49
