RV.Net Open Roads Forum: Making a Clickable Link Open a New Browser Window!
RV.net
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Making a Clickable Link Open a New Browser Window!
1492
Virginia, USA
Posted: 03/27/08 01:14am Link  |  Print  |  Notify Moderator
Here is a way to add a "clickable" link in your RV.NET forum posts, which automatically opens into a new browser window.
First, create a clickable link as you normally would:
Click here for RV.net!
This default method causes your posted link to open in the current browser window, forcing the reader to either manually open the link in a new browser window, or otherwise, click the browser's "back" arrow button to return to the RV.NET forums.
However, by adding a small line of text to your link's code, your posted link will now automatically open into a new browser window. You just need to add, or simply "copy and paste" the following text line into your link code:
"target=_blank"
directly after the web address(shown in red). Your link code will go from this:
Note that "target="_blank" or "target=_blank will also work.
There are two ways to add this text code. The first is by adding the code in the "Link" popup window as follows:
The second way is by adding the text code directly in the "Message" window:
Good Luck!
-Bob
* This post was last edited 03/30/08 01:55pm by 1492 *   View edit history
pulsar
Lewisville, NC
Posted: 03/27/08 04:46am Link  |  Print  |  Notify Moderator
An excellent tutorial, Bob. I have added a link to it in the FAQ sticky for FTS.
Given that this procedure is already described in another tutorial in the FAQs, I would imagine that most links will not take advantage of this. (However, your explanation is a better demonstration, so perhaps...)
When I want a new window, I hold down the shift-key when I click on the link.
Tom
* This post was edited 03/27/08 04:57am by pulsar *
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
swebber
Brunswick , MD
Posted: 03/27/08 05:04am Link  |  Print  |  Notify Moderator
Very Handy and very easy ! Thanks.
When I open links I usually right click, hit "Open in New Window" and off I go but that makes it a lot easier for those that do not.
Steve & Tracy Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III", FlushKing,BT spray, Reese DCHP, Atwood 3500 jack, BAL Deluxe Chocks, Weber Q
My version of an Elkhart,IN Stimulus Plan
Our Pic's
ddreisbach
Kemah, TX
Posted: 03/27/08 05:18am Link  |  Print  |  Notify Moderator
Good to know. Thanks!
As noted above, you can hold "Shift" when you click a link to open in a new window. You can also hold "Ctrl" when you click to open in a new tab in the same window (if you're using IE7).
SkiingSixPack
Minnesota
Posted: 03/27/08 06:05am Link  |  Print  |  Notify Moderator
and if anyone is using IE 7 or above, you can hold down while clicking and that will open the link as a new tab. Very handy. I use this alot on rv.net to open all links I want to read. The cool thing about this is that you can scan a list of articles, say, in the active search and the tabs will keep opening as new tabs in the background. You can then go to each one of them.
-Kent
My much better half
DS-10,DD-8,DS-7,DS-7
Our Fuzzbutt Golden Retriever-12
The greatest thing you ever can do now,
Is trade a smile with someone who's blue now,
It's very easy just...
pondputz
Hwy 7 Colorado
Posted: 03/27/08 11:31pm Link  |  Print  |  Notify Moderator
blog spot
1492
Virginia, USA
Posted: 03/28/08 11:30am Link  |  Print  |  Notify Moderator
I normally open links in a new tabbed window, by using the right-click method. But I think swebber is right! Adding this text code would make it easier for readers of the forums which may not be as browser savvy. Those who already use the "right-click+", "shift+click," etc. to open links will continue to do so, and adding this bit of text code will not effect them.
I actually posted this short tutorial at the request of several forum members who were having difficulty posting clickable links in the Class A forums. I thought I'd also add a way to make clickable links open a new browser window, for the benefit of those who may not have known that such a method existed.
