RV.Net Open Roads Forum: Tech Issues: leave Prodigy pluged in?
 > leave Prodigy pluged in?
Diabs
Toronto, Ontario
Posted: 03/27/08 08:50am Link  |  Quote  |  Print  |  Notify Moderator
just finished installing prodigy controller for new TV and TT.
Our TT stealer is going to set-up both TV&TT&BC....
My question is, right now the controller shows 2 dots....which i think is correct when nothing is hooked up. SHould I un-plug the controller when not in use?(will I shorten its life span??) or just leave it plugged in.
I did a search for this , couldn't fine anything, sorry.
AVid
SE Michigan
Posted: 03/27/08 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Just leave it plugged in. After 15 minutes or so of inactivity, it will turn itself off.
AVid
downtheroad
Tumbling Waters, Washington
Posted: 03/27/08 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Mine has been plugged in since I installed it. Two dots means power on and boost set. The lights will go out after +- 15 min. if you don't touch the brake pedal.
I'd mount it securely and leave it in.
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Wherever I happen to park
Posted: 03/27/08 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I agree, that class of device the life span is so long that it won't matter to you if you leave it plugged in or not. Might take a decade off it's life, but when you have something that can outlast your grandkids... What's a decade more or less (nothing)
jefff929
Pacific wonderland, wet side
Posted: 03/27/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I asked this same question when I got mine. It has been plugged in and forgotten since, only adjusted occasionally.
2001 Dodge 2500 QC, Diesel, Auto, 4x4 Shortbox, Stull running boards, 24.5' Prowler 5er
Diesel Bombers My Baby
Another NWBomber
swebber
Brunswick , MD
Posted: 03/27/08 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Mine was plugged in for the two years we had it until we upgraded TT & TV.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
ShapeShifter
Buffalo, NY
Posted: 03/27/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I hope it's safe to leave a Prodigy plugged in all the time. Mine's been plugged in constantly since I put it in a year and a half ago!
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
sdsdsd
Malvern,Pa
Posted: 03/28/08 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Electronics do not wear out ! Switches and relays do.
steve
Mousefart
New Jersey
Posted: 03/28/08 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Mine's been plugged in for the last 5 years. Nuff said?
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
D&E Johnson
Ontario Canada/Brenda Arizona
Posted: 03/28/08 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
ours is also plugged in. We originally had 2 red dots lit, but now only one. Could there be a problem, or is one just burned out. Prodigy still works pulling the 5th wheel..any comments? Thanks Dona
Dona and Elvin
2004 6.0l F350 turbo-diesel/4x4/crew cab/shortbed-wedgewood blue)
2007 Open Road 359RL3S
2004 Yamaha Kodiak 400 ATV
Retired early and ready to see North America!
