RV.Net Open Roads Forum: Travel Trailers: Screen cover for emergency window in Pioneer
 > Screen cover for emergency window in Pioneer
PcolaCamper
Pensacola FL
Posted: 03/27/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
We have a little 18T Fleetwood Pioneer which we have only used with hook-ups. We are planning our first dry camping trip to the Smoky Mountains in May. I would like to make a screen cover for the emergency window over the bed, so we can open it, hear the river and feel/breath the cool mountain air while we sleep. I think I've figured out how to make the screen using velcro to hold it across the window. It will be real easy to remove and won't restrict exiting in an emergency. The question I have is, is it OK to use the emergency window in this way? Will it cause a problem with leaking later, or is there some other reason I should be concerned? Has anyone else tried anything like this?
KLO
Southern OK
Posted: 03/27/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I know several people who use the emergency window like you want to. I don't think it will cause any problems if you put the screen on the inside of the window.
opnspaces
San Diego Ca
Posted: 03/27/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
My Jayco has a screen on each emergency window. I open them all the time. Go for it and enjoy camping
* This post was edited 03/29/08 02:03pm by opnspaces *
1996 Suburban 4x4. 350 Vortec, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup. 980 Lbs dry
It's so small I forget it's back there.
PcolaCamper
Pensacola FL
Posted: 03/29/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reassurance, I think I'll work on the screen today, since we can't go camping this week-end, at least I'll be in the camper! Anyone else have any ideas on how to make the sceen? My plan is to cut the velcro to fit around the metal window casing, secure it with the self-adhesive on the back of the velcro; cut the screen to fit, then pull the cover off the other sticky side of the velcro and secure it to the screen. I may need to glue it or hot glue it if the self-adhesive doesn't hold, but I've got industrial strength velcro. I don't want to make this project any harder than necessary!
