RV.Net Open Roads Forum: Tow Vehicles: 4 speed vs. 5 speed automatic???
Search only in Tow Vehicles
 > 4 speed vs. 5 speed automatic???
loufish
Burbank, CA
Posted: 03/29/08 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
The 545 is actually a six-speed, although they don't advertise it as such. Skips a gear in the upshift sequence.
Not quite...It has two different 2nd gears depending on if you're upshifting thru the gears, or downshifting when passing or climbing a hill...Still only 5 gears...
"I won't camp next to you, if you don't camp next to me!"
2004 Titan King Cab, 2wd, 5.6L V-8, 5 Speed Auto Trans, Tow Package.
2004 Jayco Qwest Baja P/U
2002 Honda XR650R
Ductape
On the Road
Posted: 03/30/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
You just tried to contradict me by confirming what I said.
Let's count them together.
First- 1
Second- 2
Second prime 3 (yes this is used on downshifts, not on upshifts)
Third- 4
Fourth- 5
Fifth- 6
* This post was edited 03/30/08 09:11am by Ductape *
Surveyor SV-234 >Equalizer> H3
Previously a fiver crew.
loufish
Burbank, CA
Posted: 04/03/08 12:17am Link  |  Quote  |  Print  |  Notify Moderator
First- 1
Second- 2
Third- 4
Fourth- 5
Fifth- 6
Splitting hairs, I admit...
It doesn't "have" 6 speeds, it just creates 2 different 2nd gears as programmed.
For instance...My Ford ranger was a 5 speed, but it had no more gear sets then the 4 speed it replaced, but because the trans is now electronically controlled, the PCM was re-programmed to run OD on top of the 2nd gear gear set to create a "3rd" gear, and would then shift to the normal 3rd gear, but this would now be 4th gear and of course OD was still the top gear, but was now "5th"...
