RV.Net Open Roads Forum: Travel Trailers: denman or goodyear tires
 > denman or goodyear tires
jdj
royse city tx
Posted: 03/27/08 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
i need to replace my tires they are 22.575d15 carlisle tires i do not want anymore of them reading all the forms i am looking at either goodyear or denman both are made in mexico i could use some help thanks james
Catfishman
North Texas
Posted: 03/27/08 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I think you'll find that Goodyear Marathons trump Denmans on this forum. But, ...... don't choose either one until you investigate the Maxxis M8008 Radials. They get some great reviews and are less expensive than Marathons.
2003 GMC Sierra 1500
5.3L - 3.73 Ratio
2002 Coachmen 249QB
If you can't fix it with a hammer, you've got an electrical problem!
mikhen
oley, pa
Posted: 03/28/08 05:56am Link  |  Quote  |  Print  |  Notify Moderator
My mechanic put Trailmark tires on my TV. He said they were about the same quality as the Firestones that were on it. After doing some research, I found the tires are made by Goodyear, just under a different brand name. They have a real nice tread pattern on them.
2002 Avalanche 2500
2006 Fleetwood Terry 300BH
Equal-i-zer
Tekonsha P3
Beer
busch2fan
Wauconda, IL
Posted: 03/28/08 07:06am Link  |  Quote  |  Print  |  Notify Moderator
If they are at all a consideration... Maxxis gets phenomenal reviews.
2006 Ford F-250 FX4 XLT Crew Cab 6.0 Powerstroke Diesel
2007 Montana Mountaineer Edition 32PRD
ProPride 3P 1400 hitch (ordered)
See my modifications here!
Midnightpumpkin
Concord Twp, Lake County, Ohio
Posted: 03/28/08 07:11am Link  |  Quote  |  Print  |  Notify Moderator
jdj
I think you will find the Marathon's are now made in China.
The Denman's are made in Mexico.
I will put Denman's on when I need to change out my trailer tires.
John U
Midnight pumpkin
2003 Dodge Ram 2500, HEMI, 2WD, 3.73 gears, 5speed Auto
Prodigy Brake Controler
Reese Dual Cam HP
2007 Rockwood 8315SS Travel Trailer
Loaded Weights:
Trailer Axles 6640#, Hitch Wt 920#
Combined Gross Wt, no passengers, 13,855#
tackhammer
Hendersonville, NC
Posted: 03/28/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
We have had Denmans for 3 years, and around 3500 miles no trouble at all . I was not sure about them at 1st after 11 years with Good year, but my tire man said they would be great. So far so good.
2006 Chevrolet 2500 Express Cargo Van 4.8 V8,3.73,4L80, K&N Air Filter, Husky hitch setup, friction sway control.
1997 Mallard 19N
2 Beagles and the Better Half.
Nothing better than old iron and camping. It will keep you young
jdj
royse city tx
Posted: 03/28/08 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
thanks everybody for your help
MrHavasu
usa
Posted: 03/28/08 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
I would not use anything made in china, I do not care whose name is has on it.
NHguy
NH
Posted: 03/29/08 06:49am Link  |  Quote  |  Print  |  Notify Moderator
May I rant?
Goodyear manages their production wherever in the world their tires are made. They carefully track failures by plant, batch, size, date etc. They can internally look up which line made which tire. They can find process problems, etc by this. They know because they sample the materials used in the manufacture of their products. It's how any company manages production. If there is liability, there is accountability. Those little numbers in the DOT code tell it all. If they started having problems they'd make the necessary production changes, including kicking someone's butt if they make stuff with failure rates outside their parameters. I use to run a tire store just off the Interstate in the desert, let me tell you any tires can fail on any vehicle. Age, maximum loads and heat brought me the most failures. Now I am back in the Northeast. The only problems we see here are from damage and failed maintenance, rarely a defect. Just make sure your tires are under 5 years old if you go where it is hot. By hot I mean southwest HOT. Over 110 degrees daily.
On the other hand if it's just China that bothers you, OK I get that, rah rah USA stuff. But remember US production costs much more, because we have ethics, unions, environmental rules etcetera. It's a real quandary.
So do you want a good product at the lowest cost? That's their goal underneath it all. Because if it were expensive they wouldn't sell, and if it were bad quality it would get around.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
RandACampin
Kathleen, Georgia
Posted: 03/29/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Nope its because the american public refuses to accept that sometimes things fail, or they might even have done something wrong like tire pressure, speeding, and overloading. And you can thank our liberal justice system as well for all the lawsuits, do think the CEO is take a sttlement out of his own pocket, heck no they pass it on in higher production costs. We could compete, but we would need a lot of cleaning up.
