Bronco4me
Ridgecrest, CA
Yes, your rabbit ear or bat wing antenna will be fine. The box will do the digital/analog conversion and pass a nice clean signal to your TV (channel control will be done with the new box).
Bronco
1992 Holiday Rambler Aluma-Lite 33CSXS
2005 Yukon Denali
1990 Bronco XLT Fishin' wagon
Wherever I happen to park
One thing you will find is that when you get to the store that list of 35 quickly becomes one or two.. The store I went to it was one. I'm watching it now, Very high quality picture, Though I got a bit of pixelation a bit ago. but the picture is very high quality. I've set two shows to record off the Converter tonight
Problem is,,, I can not (yet) control the box with the recorder (This too will happen later on)
I would look only at the brands that have the astrix beside them on the list. However, if you wind up with one that does not pass analog, it's an easy get-around, I'm doing it now.
Deen
Vancouver, WA
wa8yxm wrote: One thing you will find is that when you get to the store that list of 35 quickly becomes one or two.. The store I went to it was one. I'm watching it now, Very high quality picture, Though I got a bit of pixelation a bit ago. but the picture is very high quality. I've set two shows to record off the Converter tonight
I would look only at the brands that have the astrix beside them on the list. However, if you wind up with one that does not pass analog, it's an easy get-around, I'm doing it now. Yep, I bought two at Wal*Mart today with my rebate cards. They only had the RCA 800 in stock. Haven't even gotten home with them since I had to come to work first. I was a little disappointed to see that they require 110 V power but I can see the need. Cost was 49.97 + tax each. Now I need four more, two for the MH and two more in the stick house.
I orderd my rebate cards way back when you could firstr order them, got them on 3-25. Problem was the cards were dated from 3-03 so somewhere they sat for a 15 days or so before being sent.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'97 Grand Cherokee/4 down
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
plascell
Lynchburg, VA
Has anyone determined if any of the converters have an external wall-wart power supply and the power connection could be replaced that would allow you to power it directly from 12 volts instead?
Pete W4WWQ DX70 IC-2800 Smartire X-10 camera
2006 Chevy 3500 CC LB 4WD DRW Duramax auto-6
2003 Cardinal 29WB LX EU3000is Roto-Choks 300W from www.amsolar.com
Bronco4me
Ridgecrest, CA
plascell wrote: Has anyone determined if any of the converters have an external wall-wart power supply and the power connection could be replaced that would allow you to power it directly from 12 volts instead?
I suppose you could get a cheap couple hundred watt inverter to power it if you really wanted to.
Dick A
Spokane Valley
Moved from Tech Issues forum.
Check out the RV.Net Blogs at: blog.rv.net
Bumpyroad
Virginia
check other threads, some have various desirable features such as analog pass thru.
bumpy
Bumpyroad
Virginia
I just picked up two at Wal-Mart, the Magnavox TX-100MG9 with analog passthru for $10 and coupon.
bumpy
Correction.
My Bad, they are model TB100MW9 and are NOT the pass thru type. need to use my splitter I guess.
edited 03/29/08 03:13pm by Bumpyroad *
edwardt48
lady lake fl
If you have a old TV connected to cable without a box you still need a converter.
Learjet
Louisiana
edwardt48 wrote: If you have a old TV connected to cable without a box you still need a converter.
WRONG !!
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
