sirdrakejr
Las Vegas, Nevada
Moved from 5th wheels to tow vehicles.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
sandblast
salt lake city utah
spencefam:
your truck must be my `06 2500ctd`s twin.
excepting i weigh 30lbs more. must be my belt size.
Paul Clancy
BC Canada
Yes , get slider hitch and air bags.
Star Gazer
Nicholasville, Kentucky
Why do some say that you weigh the truck, subtract the GVW and that what is left capacity, regardless of what your axles are rated for?
My truck is rated at 8800lbs and that is what I am told the max capacity of my truck with load should weigh. And in my case that leaves around 1600 lbs available for passengers, stuff, and pin weight. Sure the axles are rated for more but the total is suppose to be the limit. And what it can pull has absolutely nothing to do with this issue.
2000 F250 PSD 4x4
2005 Four Winds 18B (mobile observatory)
My Astronomy Pics
1990 Sea Ray 350 Sundancer
spencefam
CA
Sandblast:
Perhaps you had an extra wrench or two in your tool bag!
klenger
Tucson AZ
I'd recommend the 3500 SRW. You can overload the GVWR of a 3/4 ton truck real quick with a 5th wheel. See towing weights link in my sig and do the math.
Dodge 2004.5 3500 CTD
Artic Fox 27-5L 5th Wheel
General RV Mods & Info
RV Solar - Onan Generator - Towing Weights
Digital T-Stat - Photo Album - RV Links
Retired since 2016
V10 man
Mesa, AZ
klenger wrote: I'd recommend the 3500 SRW. You can overload the GVWR of a 3/4 ton truck real quick with a 5th wheel. See towing weights link in my sig and do the math.
I believe the new Dodges are like the Fords F250/F350 and the only difference is the addition of rear overload springs.
2007 Dodge 6.7 Cummins, 6sp auto, Quad cab, long bed, white, Prodigy
2009 Shockwave T29FBSP, white & blue, tan interior, 4000W Onan, Reese Dual Cam 15K/1,500.
HarleyMedic
Sour Lake, Texas
Yes. Put a set of Timbrens on it to help the sag.
Big Sexy and BonBon
2003 Dodge 2500 4x4 Laramie Cummins Auto, Edge EZ, AEM Brute Force, Timbrens, B&W.
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
1 - Jacked up, Tricked out Golf Cart. (HERS, HERS, HERS)
ib516
Sask, Canada
Yes, but I'd opt for the 3500 single rear wheel anyway for very little increase in cost. That adds mothing more than some factory overloads in the rear (at least it used to), and a higher GVWR.
TT is a 2004 Cougar 301 BHS -- (6580# Dry, 9000# wet)
TV is a 2002 Dodge CTD 2500HD 4x4 w/3.55
Being replaced by a:
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
PICTURES
ELIM 3000 Gen
Collision Reconstructionist
MEGACAB CLUB MEMBER #1
windellmc
Indianapolis
It really depends what this 28' 5'er weighs. If you already have the truck then I would say to try it. If you are buying a new truck seriously consider the 3500 for the factory installed overload springs and extra capacity. If the 5'er is approaching 15k loaded you might even want to start thinking about a DRW.
