RV.Net Open Roads Forum: Tech Issues: leveling jacks intermittent failure
 > leveling jacks intermittent failure
RHurder
North Carolina
Posted: 03/30/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Dynamax Isata 282SL 29 footer with HWH kickback hydraukic jacks. 8 times out of ten, the jacks work perfectly.
However on the other two occassions (average), when I hit the "On" or "level" button on the touchpad on the dash the system fails to activate. Yet, after a while, the system turns on fine.
When the system does come on, it works perfectly. I cannot relate these intermittent failurs to any othe source (weather. gegree of level of campsite, distance traveled that day, etc.)
Hoas anyone got asny ideas?
Thanks,
Richard
Village Idiot
Livingston, TX/Sun Lakes, AZ
Posted: 03/30/08 08:34am Link  |  Quote  |  Print  |  Notify Moderator
On my previous Mh I had the kick back HWH levelers. They would sometimes fail to operate. It was usually when it indicated "Low Battery". The indicator is located on the operating control panel for HWH. When the batteries were low the light was dim and difficult to read. After I would charge the batteries they would work.
Also, after I cleaned the battery terminals and the cable terminals the events were less frequent.
Arnold
Memberships:
Thousand Trails,Passport America, KOA, Escapees
pulsar
Lewisville, NC
Posted: 03/30/08 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
