RV.Net Open Roads Forum: Tech Issues: brake won't adjust
 > brake won't adjust
ASTEVE
Cliffwood Beach,NJ
Posted: 03/30/08 10:10am Link  |  Quote  |  Print  |  Notify Moderator
One of my brakes won't adjust. The star wheel I don't think is turning the adjustment. I see no threads on the adjustment to adjust the brake like the other 3 wheels have. Any solutions to unfree this up. I tried going up with the brake tool and going down and niether is doing nothing.
Fishinghat
Western Washington, USA
Posted: 03/30/08 10:33am Link  |  Quote  |  Print  |  Notify Moderator
It may have opened all the way and you may need new brake shoes. Open it up and take a look. JMHO
Holiday Rambler Navigator DP, Mustang Convertible, and Honda VT1100C Shadow.
tom_kat
way upstate new york/lake george area
Posted: 03/30/08 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
takeing it apart is the only way to find out whats going on in there.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
Fisherman
Angus, Ontario, Canada
Posted: 03/30/08 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't see any threads on one half of the adjuster rod, that would indicate to me that it's screwed all the way "in" and has to go the other way to expand the brake shoe diameter. Your brake spoon tool may be just sliding off the star wheel adjuster, the two pieces of the adjuster may be seized together.
Kenneth
Washington, the state
Posted: 03/30/08 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
It could be that the last guy who put the brakes in didn't center the adjuster, or maybe the threads are jammed.
Adjusting the brakes is like life...down & out. Down on the star wheel moves the shoes out.
ASTEVE
Cliffwood Beach,NJ
Posted: 03/30/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
So I guess I should lift up on the brake spoon?
Wherever I happen to park
Posted: 03/30/08 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have had this happen on my towed a few times.. THE ONLY solution is to disassemble the brakes and replace the adjusters You might be able to do a temp fix by taking it apart, clamping in a vice and using heat and force, but you are going to want to replace them.. .Thankfully, they are not expensive as a rule.
ASTEVE
Cliffwood Beach,NJ
Posted: 03/30/08 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
If the threads are not showing about how many turns up before I start seeing threads because I just went and did about 15 turns up and nothing still happened.
