On the 2008 fleetwood revolution le there is a 400hp ISL engine with 1200ft lbs of torque. everything is fine there it is fishy when the weight comes out. the coach has a GVWR of 44,600 without a toad if i add lets say about 5,000lbs to that its just about 50,000lbs with a 400hp engine i would assume you need atleast 500hp with atleast 1,500ft lbs of torque. Does anyone think this would be a problem at 50,000lbs and 400hp with 1,200ft lbs of torque going out to the grand canyon or out the rockie mtn's?
Take a look at our signature and I will say, that you will have NO problem with the ISL400. We've been over 9000' in both Mexico and the US and the weight of our rig and toad was not a problem for the ISL.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03 FMCA #F203528 '05 HR Endeavor, 40PRQ w/400 Cummins - With -'05 GMC Sierra LT, CC Z-71, the pusher '07 Arctic Cat 500A, riding in the pusher - Our Current Location
americandream42 wrote: On the 2008 fleetwood revolution le there is a 400hp ISL engine with 1200ft lbs of torque. everything is fine there it is fishy when the weight comes out. the coach has a GVWR of 44,600 without a toad if i add lets say about 5,000lbs to that its just about 50,000lbs with a 400hp engine i would assume you need atleast 500hp with atleast 1,500ft lbs of torque. Does anyone think this would be a problem at 50,000lbs and 400hp with 1,200ft lbs of torque going out to the grand canyon or out the rockie mtn's?
Even with the added weight of the tag and whatever you should be fine .
Bill and Patti
Gizmo a Black face Tri-color Pembroke Welsh Corgi
Laci a Red and White PWC
06 Fleetwood Revolution LE 40E
05 Hyundai Elantra Toad
Member, Revolution Owners Group,FMCA,CAT RV Engine Owners Club
www.revolutionmotorhome@yahoogroups.com
