RV.Net Open Roads Forum: Travel Trailers: Hunter Thermostats???
 > Hunter Thermostats???
pmfinnegan2
S.E. Michigan
Posted: 03/30/08 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I noticed a lot of people have installed a Hunter Thermostat in their TT's. I was curious why people sleceted the Hunter Model #: 42995? Is this a special unit made to work better with TT's systems? The reason I ask is because I was curious if any digital thermostat would work? What does the digital thermostat have to have in order to work in my TT? What should I look out for when purchasing a digital thermostat?
pmfinnegan2
1998 Dodge Ram 1500 Sport
318 5.2L V-8, 3.92 Rear end
HD Transmission Cooler
2006 Max-Lite 24RS
Equalizer Hitch, Prodigy Brake Controller
Wife, 6 year old Daughter, and 2 year old son
SoLoved77
Louisville, KY
Posted: 03/30/08 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
We just purchased a new thermostat for our trailer yesterday. We opted for a regular old t-stat, one of the things you have to think about are make sure the t-stat is 12-volt and not 24 volt.
Kim the DW - 39
Greg the Cableman & DH - 42
Danielle & Gabrielle the DD's - 10 & 7
Noah & Andrew the DS's 8 & 6
'07 F-150 Supercrew 5.4L
1999 24' Skamper SK 249
8iron
Canada
Posted: 03/30/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
This has been covered quite a bit here. Search "thermostat" and every question you could ask has been answered. I would have posted a link to this info but I don't know how....
hwybnb
Posted: 03/30/08 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
I think the reason the Hunter is so popular is that Walmart sells them for just $20.
Not just any thermostat will work in an RV but any of them that are battery powered should. A lot of residential ones are designed to run on 24 volts AC, and those will not work.
tvman44
Southwest Louisiana
Posted: 03/30/08 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I used it because I could get it at Wally World for Bout $20.00.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
javaseuf
Southern Cal
Posted: 03/30/08 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
(Sigh) Ok here it is one more time.
A residential thermostat that uses internal batteries for power will work. These are designed for residential applications which are 24 volts but since the clock, relays and circuitry are powered by the internal batteries, they work on a RV's 12-volt system since the thermostats function will be as a switching device. Voltage doesn't matter in this case.
The other two types for residential systems will not work in a RV because they draw their power to operate from the 24 volt ac transformer for operation in a residential system. These are called "hard-wired" and "power-stealing".
As mentioned, the Hunter is used mostly because the instructions posted here on the Forum are for the Hunter, the price is right and they are easily available.
OK, we have covered again, the digital thermostat issue. Now let's cover operation of the Forum "search" feature!........
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Gregfromvt
Graniteville, Vermont
Posted: 03/30/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Java,
Could you please retype that, I was sorta confused..
Just kidding, We opted to buy one that we didn't have to put a switch in for the high/low fan. A litle more money at home depot but we will see in the spring how it works.
And I also called the tele number on the back of the paperwork and the CSR their said that thermostat would work great in our TT.
Until then, Happy Camping and Good Luck
2000 Chevy Silverado 4x4 1500
2007 Heartland Trail Runner 2700 BHS TT
Loopy
Western Pennsylvania
Posted: 03/30/08 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Greg, do you have a link to that stat or at least the make and model? I'm looking for one that has the HI/LOW/OFF switch instead of having to add one.
Thanks!
Bryan , Jess, and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
Capn Courage
Ontario
Posted: 03/30/08 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of people use the Hunter thermostats because they are inexpensive and available at Walmart, I have a Noma 52-2593-2 thermostat that I picked up at Canadian Tire on sale for $9.99, the wiring is the same as the Hunter.
Norm
Capn & Mrs. C
2004 Rockwood RLT23FB
2002 GMC Safari
Eaz-Lift W/D hitch
Reese Anti Sway
sue.t
Vancouver Island, BC, Canada
Posted: 03/30/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
If you're buying a digital thermostat, then consider getting a programmable one. A bit more costly, but well worth the investment. For $34 (RONA hardware store) I can set the thermostat down for the nightime and have it come on in the morning to heat the trailer (and wake us up). For our last trailer and our present one, I purchased a 5-1-1 (program Mon-Fri, Sat & Sun separately) only because I like the features more than the 7-day programmable, or 5-2 day programmable ones I see. It just means I have to set three programs for the week, rather than one.
sue t.
Pictures from Our RV Adventures to Yukon & Alaska
