rstanek
Holmen, Wis.
I have a 2007 Eagle 322FKS with appro.1400 lbs. tongue weight. What would be the best power jack. thanks in advance.
2007 Eagle 322FKS
2008 Chev Silverado 6.0 4:10
rstanek
Holmen, Wis.
Attwood?
The Garrells
Cheraw, SC
We have a Eagle 278FBS. We use a Barker. It has worked well.
Mike & Terri
2005 Jayco Eagle 278FBS
2006 Chevy Silverado 2500HD, Vortec 6.0L V8 300 HP engine, 4.10 rear axle, 167" wheelbase
Equil-i-zer brand hitch
Prodigy brake control
McKesh mirrors
View our camper here
SKG
Emerald Park, Saskatchewan
i just installed the Barker 3500 VIP and it was a simple job. The only issue I ran into was the distance to the battery (wire). Its on but there was only about three inches to spare.
cheers
2007 Jayco Eagle 314 BHDS
2007 Dodge Mega Cab 5.9 CTD
skipnchar
Topeka Kansas USA
I'd get one that goes up and down when you push the button. They're kind of a "one size fits all" item. If it raises and lowers your trailer that all you can expect. If it doesn't it's totally useless. Most any 3500 lb. capacity jack will do as well as any other. Good luck / Skip
rstanek
Holmen, Wis.
thanks skipnchar, I should have known better than to ask a question...
davidj54
South Alabama
Skip gets that way sometimes . Most here seem to prefer the Barker 3500lb unit. With a 1400lb TW I would get as large a model as I could.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
Zebich
canyon city,OR USA
I use a Barker 3000lb model, If I do it again I would buy the
3500 Lb Model just to have a little cushion. I would suggest
you get one with "elecric limit swiches" which stops the jack's
motor when it reaches either extreme position. I had my jack
partially fail because I sometimes ran it to it's limits and
the jack I have had no mechanical over ride clutch so would make
a loud noise and finally it would be somewhat noisy all the time
and I replaced the screw mechanism.
According to the parts list, Barker apparently makes a model with
the electrical limit switches.
FormerHR
Inez, Texas
We had an Ultra-Fab 3002 on our Prowler (3000 pound). I took it off last week when we traded it in. The time we had it on there I was happy with it. Made all that up and down during hook up a lot easier.
Ryan and Persephone (Seph)+ a boy (7) and girl (5)
2005 Cummins Quad Cab 2wd
2008 Terry 295BHDS
Pullrite Superglide
Dual Honda EU2000i's
fourcamping
Columbia, South Carolina
We have the Barker 3000. Our North Trail has a 500# tongue weight and in order to get our Blue Ox Sway Pro hooked up, we have to crank the trailer and car up a good bit to get the bars on. And we have no problems.
Jennifer
Jennifer, the DH and three girls (one furry)
2005 Toyota Sequoia
2008 North Trail 28BHS
