Krause
Ontario, Canada
I just started driving my "new" 2007 Chevy diesel pickup a couple of weeks ago and I have noticed that the engine temperature, when towing nothing, has crested 212 degrees F. This seems warm to me but then I am not sure where a diesel should be. We are driving it with any towing down to Florida in a couple of weeks so I guess I will really see it then but does anyone have any comments on where the temperature should be?
SKYTROOPER
OCEAN CITY,MD.
My Duramax never gets to 200, even when towing. The trans will run about 100 over outside temp.
AVid
SE Michigan
I go between 195 and 200, towing or not.
AVid
gillguy
Valdosta, GA
190-200 not towing
tranny temp about 130-150
195-200 towing
tranny 150-180
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
Krause
Ontario, Canada
I am going to book this with my dealer to take a look at it...any ideas that would cause it to run as warm as it is?
jello
GA
It's not running warm that's normal. 210 is the normal operating temp. I thought the same thing when I first got mine.
AVid
SE Michigan
Gauge could be wrong...fan clutch no good...low on coolant....water pump low function..restricted exhaust. Good to have dealer check it out, at least get it on record.
AVid
Sundowner1
Chesapeake, VA
That is not abnormal at all. There are two thermostats in your engine. The first one starts to open at 183 and is fully open at about 205 or so. The second one starts to open around 195 and is fully open at 213 i believe.
My 04 Duramax runs at a constant 210-212 whether emptly or towing. If I go up a long upgrade while towing (6-8 miles), It will get up to 220 but the fan kicks in and it comes right down.
I even replaced both thermostats and it still acts the same way exactly.
Sundowner
04 Chevy 2500HD, Duramax, ext cab, short bed, 4X4
08 Fleetewood Quantum 325RKTS Gross wt, 13500 lb.
shadoow
South Texas
jello wrote: It's not running warm that's normal. 210 is the normal operating temp. I thought the same thing when I first got mine.
Agree. My 2008 D/A runs at 210 no matter if towing or not, cold outside or hot. It's normal.
KZ 33P Toyhauler
2008 GMC 2500HD D/A
2006 Ultraclassic
1978 FLH
killerbee
PHOENIX USA, Never hot
Are you hearing the fan come on?
Duramax Cooling System Survey
GM Overheating
Engine Oil Cooling
Tune Your Own GM Vehicle
