RV.Net Open Roads Forum: Fifth-Wheels: How do you store your sewer hose ?
 > How do you store your sewer hose ?
Page of 5
charlan
Okanagan, British Columbia, Canada
Posted: 04/02/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
downtheroad wrote:
You have a brand new Silver Back (a beautiful unit) that has no provision for sewer hose storage or at least what you do have is not useable.... Incredible to me that RV manufacturers can get away with this kind of nonsense.
Don't these guys test or use their products in real life camping situations? Where do they think you are going to keep your hose? Under your pillow?
One good thing I can say about ours it has a builtin sewer hose storage, cant understand why they dont all have one.
2002 GMC 3500 SLT 4X4 HD LB Duramax 6.6 Turbo Diesel Dually
Hijacker 4 Way Pivot, Prodigy Control, Firestone Ride-Rites
2004 Prowler Regal Advantage AX6 36.5 FLTS
Lippert Frame Failure
TubaPete
Comstock Park, MI
Posted: 04/02/08 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I simply store mine coiled in a plastic bucket. The bucket fits into a corner of the basement near the toilet pipe where nothing else would go anyway.
Tuba Pete
GlacierBayGuy
Holland MI
Posted: 04/02/08 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Our trailer had the caps riveted in also. I removed the rivets and had to drill the holes in the top and bottom of the bumper for the caps to lock in place. That's where we store the hose now.
alfresco
Bloomfield, NB, Canada
Posted: 04/02/08 08:32am Link  |  Quote  |  Print  |  Notify Moderator
I went to my next door neighbour who is a construction contractor. He had just the right size PVC pipe which I mounted on my rear bumper with two brackets. He also had rubber caps that fit over the ends. I drilled a few holes in the bottom. No rust worries.
Patti & Ron
97 1500HD 4x4 Chevy
23' Hornet 5er
Mallo
PA
Posted: 04/02/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Quint Da Man wrote:
Good weather is fast approaching (okay not fast enough)and my brand new 5th wheeler has been sitting in my driveway for a few months. Wife and I are starting to load it and learn it. I'm trying to figure out the best way to store the sewer hose. I noticed some trialers have a storage area in the rear bumper. My rear bumper has caps that come off but pop riviets in the bumper prevent me from sliding anything inside it. I am considering just drilling out the pop rivets, what have others done for storage ?
Our Nu Wa has a storage compartment for it just under one of the front hatches, in fact the dump valves are in the same compartment so they can be locked away.
I've seen a number of RVs with the PCV pipe straped to the back bumper for storing it. Seems a cheap and easy solution a piece of pipe the right lenght and two end caps for it.
If not for that I'd likely use the fridge, or maybe not.
Mallo
Eloise - 2000 F350 7.3 DRW XL, Reading Flatbed, King Ranch Leather, AIS, MBRP 4" Ex
The Chinese Princess - 2007 Hitchhiker II LS 32.5 LKSBG
Your Kung Fu is weak!
C.B.
APPLETON WI USA
Posted: 04/02/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Here's what I did after seeing something similar on this forum.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
TORQSHIFT AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE
PRODIGY BRAKE CONTROLLER~C-BETR MIRRORS~ROTOCHOKS
CB Family Fleet
Butch&Barb 03Cardinal~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 04Jayco
Quint Da Man
Peabody, MA
Posted: 04/02/08 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Thats a real nice set up. Whats the trough made from a piece of gutter ??
2008 Cedar Creek Silverback 30LSA
2007 Chevy Silverado 2500HD D/A
PackerBacker
Montreal, Quebec,Canada
Posted: 04/02/08 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Store our's in a Rubbermaid container in my truck toolbox. I keep all the fittings and tank flusher there also. Two or three times a season, I fill it with water and a good amount of bleach to more or less sanitize the hose, hardware and container.
Eric
2009 Holiday Rambler Admiral 33SFS
Good Sam's - FQCC/Camping Quebec
My Photos
tom_kat
way upstate new york/lake george area
Posted: 04/02/08 08:57am Link  |  Quote  |  Print  |  Notify Moderator
one in the outside storage tube and two in a pail in storage compartment.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
C Schomer
Buckeye, Az.
Posted: 04/02/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
The first owner put all the sewer stuff in a Rubbermaid tub in the basement and I still have it there. On our previous 5er, I used .032 alum. gutter coil and boxed in a big area between the frame rails and the lower trailer skirt and put an access door in the skirt. That was the best - it was out of sight and didn't use up any basement area. I need to do that to this 5er. Craig
2003 Dodge HO CTD, NV5600, 4.10. Real 1Ton - pregnant with twin spare tires, 4WD - all on the rear. Aurora 2000 turbo, Diablo Predator, 4" muffler. 98 Sunnybrook 30RLFS 5th wh. WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
Page of 5
