RV.Net Open Roads Forum: Fifth-Wheels: Pin weight VS GVW
 > Pin weight VS GVW
NGRRFan
Colo. Spgs., CO
Posted: 04/03/08 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
coachman05 wrote:
what about 2 campers that have the exact same lay out? We are looking at a Wildcat and Rockwood Ultra lite and for whatever reason the Wildcat weighs more but, has a liter pin weight.
Assuming that both trailers do have the EXACT same floor plans, it boils down to how the units are constructed and where the axles are mounted in relation to the pin and if one rig has an extended pin or not.
Rich, Kim, and
Tobi the rescued dog
Oreo (waiting for us at the Rainbow Bridge)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/03/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Pin weight affects the suspension of the truck.
Combined Gross Weight (the weight of the truck and the trailer) affects the trucks power train. (Engine, Transmission, etc)
00 Jayco Eagle 313 5th
01 F250 PSD S/C S/B
Star Gazer
Nicholasville, Kentucky
Posted: 04/03/08 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
So Cool Canuck, have you weighed your rig? I have the same truck, except 4x4, long bed, and if I follow the rules, I am going over my max pin with most nice 30' range 5th's.
If I remember correctly when I got weighed that I had about 1600lb capacity with full load of fuel and me.
2000 F250 PSD 4x4
2005 Four Winds 18B (mobile observatory)
My Astronomy Pics
1990 Sea Ray 350 Sundancer
Cool Canuck
Posted: 04/04/08 06:22am Link  |  Quote  |  Print  |  Notify Moderator
My pin weighs around 1,400 lbs. Ready to go, the truck weighs 4,400 front and 4,400 back. It wouldn't bother me to put another 1,000 lbs on the pin.
donn0128
Pronounced Ore-gun
Posted: 04/04/08 07:59am Link  |  Quote  |  Print  |  Notify Moderator
True pin weight is generally considered to be 20% of the fivers GVWR. So based on the (laugh here) "dry weight" I would estimate that either of the mentioned trailers will have a GVWR of 8000 to 9000 pounds. That puts the pin weight squarely in the 1800 pound range. Now, depending on which motor and which rear end gear ratio the intended truck has by adding heavier duty tires and air bags the OP might be OK on flat ground. But from the experiences I have had with loading my company 1/2 ton truck up with about 700 pounds and trying to go up and down hills he will not be very happy with the combination no matter which trailer he chooses.
Donn
 > Pin weight VS GVW
