charwan
Dawsonville, Ga.
Deputy Chief P.O. wrote: I just had the oil in the motorhome engine and the oil in the generator changed. It cost me $360. Boy was I in shock after getting the bill. Next time I will do it myself.
Did they KISS you afterward?
N4FAP
mockturtle
Northwest
In days of old, elves were hired to service generators, but now the elves are gone--possibly due to exposure to generator fumes.
There are many examples of ridiculous designs that make it nearly impossible to access things for repair. Makes me very, very angry!
2000 Aerolite 19RB TT
1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
Deputy Chief P.O.
Linden, California
To Charwan:
That was the least they could do since I took it from behind! LOL. Never again, it hurt! LOL
dapark
SLC, UT
$360.00 !!! I would have wanted the kiss and then an egg mcmuffin from them. Glad I do all mine myself, cost about $12.00 for filter and oil for Onan, then about $30.00 for oil and filter for engine.
2005 Allegro Bay 37DB WH22
1999 Durango is the Toad or
the Milan or the ATVs. Depends on
our compass heading.
david_w28
Michigan
No problem on mine, very easy to access.
MS Bowhunter
Collierville TN
Fleetwood will run the exhaust pipe right below the access door so it wont open completely! Now that took a real genius.
AeroP
Emery, SD
dav5942 wrote: Had the same problem with Power Tech and the Cummins filters. Found an adjustable belt wrachet filter wrench at Napa that fits all size filters. Worked like a charm-threw away four other filter wrenches.
You got it right, I had the same pleasure with the NAPA strap wrench.
AeroP
AeroP
99DSDP
othertonka
Stockton, CA
You didn't say what model Onan you have. I have the Onan Marquis gold 5500 Gasoline model. Onan and aftermaket places make a "cup" type oil filter wrench that slips over the end of the filter and you use a 3/8 drive extension and a 3/8 ratchet and turn it right off. Without the wrench, you can never get your fingers or hands on it to remove it. So you need the right tools,, about $6.00 for the wrench and no problem at least with the Marquis Gold.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
jmcnab
Toronto Ontario Canada
Be thankful your Onan in in an RV and not enclosed in a sound-shield in the bilge of a boat.
02 Yukon Denali XL
08 KZ Spree 324BHS
Daveinet
il
You folk got to be kidding me. Your generator is not on roller drawer guides?? Filter and drain are on the door side, but even so, my generator rolls out the side of the coach for full access to both sides. I assumed they are all built that way. Its really the fault of the coach manufacturer, not Onan. The coach manufacturer should have enough brains to put the genny on drawer slides.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
