RV.Net Open Roads Forum: One Electrical Outlet not working on Shore/Generator power
 > One Electrical Outlet not working on Shore/Generator power
John&Sandy
Madison, SD
Posted: 04/06/08 09:57am Link  |  Print  |  Notify Moderator
We have an odd situation which we can not figure out, any assistance would be great.
We have ONE outlet in our motorhome that is a cabinet which is where our microwave plugs into. We have power to the outlet when we are running through the batteries/inverter; however when we plug it into Shore or run the Generator we have NO power. All of the other outlets in the coach work just fine under, but this one. We have tested the outlet with a voltage tester and get the same results, and the microwave will run just fine when we run an extension cord to one of the other outlets.
So whats up?
Thanks, Sandy
John and Sandy
2007 Holiday Rambler Ambassador 40 SKT
BFL13
Victoria, BC
Posted: 04/06/08 10:13am Link  |  Print  |  Notify Moderator
The microwave outlet goes straight to the inverter AC outlet, while the other outlets go through the main AC Dist panel circuits.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
JFG
TN
Posted: 04/06/08 10:39am Link  |  Print  |  Notify Moderator
Sounds like my setup... the inverter must be "on" for this outlet even though you are connected to shore or genset
Fred
John&Sandy
Madison, SD
Posted: 04/06/08 11:51am Link  |  Print  |  Notify Moderator
JFG - I guess I didn't state that, but the inverter was on even when we were plugged into shore/generator power.
othertonka
Stockton, CA
Posted: 04/06/08 01:21pm Link  |  Print  |  Notify Moderator
It sounds like that one outlet is only wired directly to the invertor and will only work when the invertor is ON. Since you said it would not work when plugged into Shore or gen power even with the invertor ON, it seems that when you plug in, the invertor gets disconnected from this circuit somehow. I have no idea where to look but who ever installed the Invertor and wired it like this made a mistake somewhere. What else does the invertor power when you are only operating from the battery? Is it just the Microwave? Or are there other outlets HOT from the invertor like the television? Does the invertor have a built in battery charger? If so, could be that when you plug in to shore power, the invertor switchs to the battery charger and thus you have no voltage to the microwave. Just a guess but something to look at.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Wherever I happen to park
Posted: 04/06/08 02:19pm Link  |  Print  |  Notify Moderator
Some inverters have a built in automatic transfer switch, Some use an external one and some,, You move plugs around as needed
I'm guessing a failed transfer switch
Home is where I park it.
MELM
GA
Posted: 04/06/08 07:06pm Link  |  Print  |  Notify Moderator
Please post the make and model of the inverter.
If it has a transfer switch built in, that may be the problem.
But, check your main circuit breaker panel for a breaker for the microwave. If it is tripped, there will be no power to pass through the transfer switch for that receptacle. A heads-up - some breakers barely show that they are tripped; if one is labelled for the microwave, you should turn it firmly off and back on.
Also, if you have an EMS system and the microwave is one of the items that it controls, check it.
Mel & Mary Ann; Mo'Be (More Behave...) and Bella
"If you have an RV, you don't need another hobby." Comment from a friend...
90 Champion LaSalle MH 29 ft P30 (89 Chassis)
Visit The Official Blog of the Open Road
John & Angela
World Travelers.
Posted: 04/06/08 08:20pm Link  |  Print  |  Notify Moderator
Have to agree with this one. Transfer switches occasionally fail. provide the make and model of your inverter and we'll be able to tell if it has a built in transfer switch.
MELM. The reason I don't thin it's a breaker is that it seems to be sensing the 120 meaning the 120 to the inverter is good...at least on the sense side. Never hurts to check the breakers though.
* This post was edited 04/06/08 08:33pm by John & Angela *
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
MELM
GA
Posted: 04/06/08 08:45pm Link  |  Print  |  Notify Moderator
John % Angela - Some inverters have multiple AC inputs from separate breakers for separate circuits. That's why I asked for the inverter info.
One could be causing the inverter to function correctly, but another could be missing and not feeding the circuit when on shore power.
Mel
Posted: 04/06/08 08:51pm Link  |  Print  |  Notify Moderator
Good point MELM I tend to assume the OP did things like check breakers... I know, I should not do that, but checking breakers and fuses is so automatic for me I tend to over look it.
Often it is the simple stuff that messes us up
